lakewood alignment kit
Old January 15th, 2012, 06:08 PM
Tony
archeryshooter's Avatar
anyone out there ever used a lakewood alinement kit for aligning a scatter shield? should it be done if so do i have to have the kit or can i use my own tools like dial indicater ect? if so how is it done?
archeryshooter is offline
Old January 15th, 2012, 08:24 PM
4speed's Avatar
I'm not aware of a "kit". Unless you are talking about alignment dowels, which you won't know what you need until you check your alignment. I personally believe all bellhousings should be checked for run out. Others may disagree (the factory didn't do it). I have a video I found on you tube (there are others) that gives you an idea of what is involved. And yes you can use your own dial indicator with a magnetic base.
Russ
4speed is offline
Old January 17th, 2012, 03:37 PM
Run to Rund's Avatar
It is definitely worth while to align the bell housing. I drill my Lakewood dowels and tap 5/16 x 18 thread so I can pull them out with a slide hammer--it is rare to get them perfect the first time; try for zero total indicator readout. Lakewood makes .007, .014, and .021 offsets and I keep all three in my tool box for the "next" block or housing.
Run to Rund is offline
Old January 17th, 2012, 08:08 PM
Funkwagon455's Avatar
Regardless if you have the kit or not, you will need to check the runout with a dial indicator. If the runout is within the limits specified with the stock alignment dowels, well then your golden. If not then dowel kit will provide the necessary adjustment needed to bring it in. It is not really difficult, or time consuming and gives you the peace of mind knowing that your investment as well as your ankles are better off. Good luck with the project and thoroughly enjoy thrashing on it!!!
Funkwagon455 is offline
speck1148
December 30th, 2012 02:31 PM
WTony
December 18th, 2012 12:06 PM
RandyS
September 29th, 2012 12:26 PM
66-3X2 442
June 19th, 2012 08:17 AM
bummerino
November 11th, 2011 03:04 PM
Quick Reply: lakewood alignment kit
