Leak
Leak
1972 Oldsmobile Cutlass
350
Th350
Transmission leaked at kickdown cable o-ring even when car was not running.
Leaked on floor and then stopped.
Is it possible that Transmission was overfull and kickdown rubber o-ring is bad?
Definitely Transmission fluid on stick abuve full when cold. No 100% sure if stick is correct as replaced without original.
Please Advise?
Thank you
350
Th350
Please Advise?
Thank you
350
Th350
Please Advise?
Thank you
350
Th350
Please Advise?
Thank you
61olds88
November 29th, 2023 09:26 AM
1983Olds98
Ninety-Eight
January 11th, 2019 03:23 PM
