Shifter change from 2 speed to 3 speed
Hello All!
I am curious if someone here in the transmission section could guide me in understanding how to change the column shifter from PRNDL to PRNDL2L1, as well as if there is anything that needs to change at the transmission to make the transition complete.
Thanks in advance!
Bryon
Thanks in advance!
Bryon
If you just want the shifter to work, just line-up PRN and the low gears will just be there but not showing. The gear lever will keep going down for each gear as you select it. If you just leave it in 'Dr' the rest won't matter.
Your column shifter and stock linkage should be OK w/ a 3-sp trans, I believe the sweep angle of the shift control shaft on the trans is the same (or close enough) between the Jetaway and TH350/TH400. If you were going to an OD 4-sp trans like a 200-4R, you'll probably need one of these:
http://www.kugelkomponents.com/zenca...c371d40277e8a7
This allows you to change the ratio between the column lever and the trans shift control shaft, which operates through a larger angle/sweep than a Jetaway.
If you find a source for parts to change the dash indicator from PRNDL to anything else on your '68, please post up. I've only been able to find revised indicators for Chevys (Novas / Camaro / Chevelle), which won't work in a Cutlass.
PRNDL2L1
Airboddy knows Olds and Pontiac 3-speed automatics say "DSL"! SOOPER range, hell yeah!
I'm drawing a brainfart- is the 68 shift quadrant in the speedometer as later or is it in dash below speedo like the big cars were? If it's in the speedo, should be able to find a THM car speedometer face. Bound to think some THM A-body cars could supply a shift indicator lens. Most Vista Cruisers had THM.
Chevrolet and Buick heresy!
oldcutlass, would finding one for a TH400 mean some junk yard surfing? Or, is there a place that sells that kind of stuff?
After looking for a bit, the automatic speedometer seems only available for a 2 speed trans and the 3 speed seems to be floor shift only. Maybe some of the other guys may know if it was floor shift only.
If you hook up your linkage it will work properly showing 1st at the L, 2nd will be just to the left, and D will be a little to the left of drive, neutral will be close to the N and R and Park will be lined up. I use the 2 speed indicator with my T400.
marxjunk
June 12th, 2014 12:34 PM
