th 350 linkage
Old September 1st, 2008, 06:07 PM
65cutty's Avatar
th 350 linkage
swapping in a 350/350 in my 65 cutlass, colume shift, eng and trans from a 1973 cutlass, car is gone so cant get the shifting or down shift rods from. can I use any mid size gm linkage meaning down shift and selector rods and mounts from the firewall? chevell, skylark nova as long as the trans is a th350 and colume shift, is there a company that sells these?
65cutty is offline
Old September 1st, 2008, 06:12 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
www.shiftworks.com
J-(Chicago) is offline
Old September 1st, 2008, 08:07 PM
The linkage parts from your 65 should work fine. You will need the kickdown cable and a bracket. Use the cable and bracket from a mid-70s small block Olds.
joe_padavano is offline
mike623
October 4th, 2010 07:50 PM
dharlett
September 23rd, 2009 03:30 PM
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
March 31st, 2005 08:15 PM
<Cody>
August 10th, 2003 10:00 PM
Quick Reply: th 350 linkage
