Th 400 problems
Th 400 problems
This has probably been answered somewhere on here but my issue with the transmission is odd. I bought this from a guy out of state about 6 months ago, I finally got the engine done and everything put back in the car. I topped off the trans fluid and took it down my road well I seems to only have 1st and reverse. I called the guy and he is adamant that its a good unit and would be losing nothing by lying at this point am I missing something. As stated above it a th400 with reverse manual valve body, hurst quarter stick and I've double checked the linkage and its adjusted perfectly. Any help would be great im getting ready to pull it and have it gone though just thought I'd ask you guys first thanks.
There is no connections to the trans other than cooling lines and shifter linkage. Could this be a torque converter issue. This is what the guy said about it when asked, Hey good morning the converter was a 3500 stall neutral blade angle street strip no spragless parts. Wouldn't recommend for no power additives
Does it have a vacuum modulator?
Next, pull the governor, see if it has one or if it’s been modified.
Pull the oil pan, see if it have governor tubes? Detent solenoid? Those parts are usually omitted for a manual valve body.
viper771
28
April 19th, 2014 07:31 PM
Ron McHugh
May 15th, 2013 01:23 PM
