TH350 Kickdown Cable Identification
Old December 14th, 2020, 09:22 AM
NTXOlds's Avatar
I had a local transmission shop swap out my failing Jetaway for a TH350 in my 68 Cutlass. The shop did not attach the lockdown cable, but the owner told me that it was the style that attaches to the carb via a bracket. I am attaching two photos of this cable.
Can you confirm that this attaches to the carb and not to the pedal?
NTXOlds is online now
Old December 14th, 2020, 09:56 AM
The black plastic piece with the square tabs sure looks like it would connect to a carburetor mounted bracket.
Fun71 is offline
Old December 14th, 2020, 10:22 AM
I agree, looks like a carb mount style replacement.
The proper firewall mount style has a mounting tab similar to the throttle cable, and has a sliding tab that grips the cable for adjustment It’s been a long time since I messed with one, my memory is a little fuzzy
matt69olds is offline
Old December 14th, 2020, 10:24 AM
NTXOlds's Avatar
That is what I thought, too, but I think that the style that hooks up to the gas pedal has a square fitting, too.
I expected this cable to have a slotted fitting on the end to attach to the carb based upon other photos I have seen, but it looks like the brass fitting attaches to the carb and that the length is adjusted very simply by tightening the screw.
Old December 14th, 2020, 10:25 AM
I found this online, this is the clip I was describing. A picture is worth a 1000 words!
Old December 14th, 2020, 10:28 AM
NTXOlds's Avatar
Thanks, Matt! I agree. It definitely does not look like the pedal style from that photo.
Now I just need to find the right bracket.
Old December 14th, 2020, 10:32 AM
The 69-72 Cutlass cars ran the TH350 kickdown cable to the accelerator pedal, not the carb. I've done the TH350 conversion on a 68 and you can use the same parts. You need to cut a square hole in the firewall below the accelerator cable. You need a correct TH350 pedal also. The repro houses sell the correct Oldsmobile cable. Note that the TH350 pedal has the extra tab for the second cable.
joe_padavano is offline
Old December 14th, 2020, 11:12 AM
NTXOlds's Avatar
Joe, thanks for the detailed explanation with photos and the link to the proper cable.
I am planning to swap the intake / carb to the Edelbrock Performer and a Holley Street Warrior carb over the holidays when I finally have some time off work. Eventually, when I have time to do a full engine rebuild, I intend to switch to a Holley Sniper.
Both the Sniper and the Street Warrior carb have the TH350 cable attachment point. If I am doing this, is there any reason to switch the cable to the pedal style from the cable that came with my transmission?
Old December 14th, 2020, 11:14 AM
So long as the throttle arm provides the right cable pull ratio, it will work fine.
Old December 14th, 2020, 11:25 AM
NTXOlds's Avatar
Thanks, Joe. I will try this first using the cable that came on the transmission. I can always buy a new cable for the pedal version if it doesn't work.
Old December 30th, 2020, 06:25 AM
NTXOlds's Avatar
Just an update for future reference.
After changing my intake and carb to an Edelbrock Performer and Holley Street Warrior, here are the parts that were needed to connect my factory throttle cable and my TH350 kick down cable to my carb.
Spectre Performance 24283 Throttle Cable Bracket - This has adjustable brackets for both the throttle and kick down cable. I got mine at AutoZone, but it is available at Amazon, too. It bolts up to the base of the carb, and the adjustable set screw is really valuable for getting the alignment correct. I highly recommend this. The Mr. Gasket version does not have an adjustment for the throttle cable, and would not work.
Amazon Amazon
Here is the Holley part for attaching the kick down cable to the carb.
https://www.holley.com/products/fuel...ge/parts/20-40
Old February 4th, 2024, 08:30 AM
Rgdickson's Avatar
NTX, do you have a pick of that Spectre Bracket on your Edelbrock Performer with the TH350 Kickdown cable?
Rgdickson is offline
Old February 4th, 2024, 10:54 AM
NTXOlds's Avatar
@Rgdickson Here is a photo of the Spectre bracket with the Performer and the TH350 lockdown cable. It worked fine. It flexed more than I wanted, and I wasn't happy with the return spring setup despite trying various setups on both sides of the throttle.
I ended up switching to a Holley bracket which worked much better. It uses two of the carb bolts, so it is rock solid secure, and it is very adjustable.
https://www.summitracing.com/parts/HLY-20-112
Old February 4th, 2024, 01:34 PM
Rgdickson's Avatar
th350 hookup 1971 Cutlass Supreme
Found that it was already there at peddle but not hooked up, going to get a retainer grommet and try there first thanks
76cutlass
April 5th, 2017 05:50 AM
trevor1400
August 31st, 2016 03:15 PM
Nighthawk
November 15th, 2013 07:27 PM
dschallock
July 21st, 2012 08:30 PM
archerbob
September 12th, 2011 01:29 PM
Quick Reply: TH350 Kickdown Cable Identification
