torque converter help
Old November 12th, 2010, 10:07 PM
new user
bigwillystyle's Avatar
I just had my transmission rebuilt along with a rebuilt Torque Converter. When the TC is seated all the way against the pump, how much distance should be between the TC mounting bolts and the Flexplate?
With the transmission bellhousing all bolted up to the engine block and the TC is seated all of the way up against the pump there is approximately 1/4 inch of space.
bigwillystyle is offline
Old November 13th, 2010, 03:12 AM
Rickman48's Avatar
Sounds a little tight, maybe on the low side of recommended clearance.
Are you sure it's seated?
Shoud fit into the notches on the pump - as you turn it, you'll feel it 'seat' - and go in about an inch.
I usually put a film of wheel bearing grease on the shaft to avoid wasting the seal, too!
Rickman48 is offline
Old November 13th, 2010, 11:52 AM
If you can spin the converter without it dragging on the flexplate before you bolt it up, you're fine. Typically with the converter up against the pump you can barely get a finger in between the converter and the inside of the bellhousing
joe_padavano is offline
Olds luvr
April 10th, 2014 05:51 PM
Stevec
April 20th, 2012 05:46 AM
rayfrausto
April 25th, 2011 01:02 AM
SPEEDROCKET
December 18th, 2007 06:35 PM
Surfrat67
May 14th, 2006 03:42 PM
Quick Reply: torque converter help
