Tranny Swap
Old May 3rd, 2003, 10:46 PM
JP63's Avatar
Question
I've got a 1983 Olds 98 Regency 2-door w/ the 307/ 200R4 combo. I'd like to swap in the 350/ TH350 from my 75 El Camino. The engine should be no problem, what concerns me is the trans. I understand the transmissions are the same length, but does anyone know if I will need the drill the frame in order to move the crossmember forward enough?
JP63 is offline
Old May 19th, 2003, 02:05 PM
connected100's Avatar
Post
If they are the same length tranies then just measure back from the end of the splined output shaft back to the center of your tranny mount. If there is any difference move crossmember accordingly. Hope this helps. Steve
connected100 is offline
TOONLOVESCHERYL
February 4th, 2016 06:30 AM
papabear4208
May 26th, 2007 07:24 AM
crank.it
November 12th, 2006 04:04 AM
joelow83
July 13th, 2006 03:19 PM
Winnipeg Cutlass
April 17th, 2006 03:15 PM
Quick Reply: Tranny Swap
