Auto to 4spd conversion, where do i cut the floor?
Old March 30th, 2013, 06:13 AM
TWP442's Avatar
Hello all,
I am doing a manual conversion on my 1971 442. Where do I cut the floor for the shifter to come through?
TWP442 is offline
Old March 30th, 2013, 11:51 AM
My442's Avatar
I have the the floor section that has the factory cut hole.
You can rent it from me.
My442 is offline
Old March 30th, 2013, 02:22 PM
Run to Rund's Avatar
After you install the trans, you will see where the shifter goes. Different shifters take different hole positions.
Run to Rund is offline
Old March 30th, 2013, 05:38 PM
TWP442's Avatar
Where can I find a diagram of where it should be from factory?
TWP442 is offline
Old May 24th, 2013, 06:37 PM
rpclearwater's Avatar
Shifter hole
Im doing the same project and was wondering the same thing somewhat? Im gonna put the trans in without the shifter handle and just the shifter body on and mark the floor straight up from it and slowly cut away til the handle can go in. Then start going through the gears and trimming as necessary til the shifter handle doesnt hit the side of the holes. Then I will take the shifter tunnel hump I bought from the parts place and put it over the shifter handle and set my console in and go through the gears and make sure it doesnt hit sides of console and then mark where tunnel hump goes exactly and trim up hole and weld it in and seam seal it and put it all together. I have searched for pics and diagrams also but cant seem to find any? If you find a better way please let me know.
rpclearwater is offline
yamahondarider
23
April 20th, 2018 06:31 AM
rlm765
March 2nd, 2013 06:49 PM
rennoc442
June 17th, 2012 07:57 PM
oldzy
22
April 13th, 2011 05:53 PM
bmort
May 9th, 2010 01:24 PM
Quick Reply: Auto to 4spd conversion, where do i cut the floor?
