Torque converter
Old June 24th, 2017, 01:44 PM
simpleold's Avatar
Torque converter
Hi there I would like to upgrade the torque converter on my 1969 Oldsmobile delta 88, 455 engine , the car engine is stock but i guess I would like for it to go a little faster, faster take off, it Is very decent now being stock but a little bit more juice will be nice, currently have dual exhaust super 10 flowmaster, with the Thornton s w exhaust manifolds, 455 torker intake manifold, edelbrock carburetor 1407 750 CFM, HEI distributor, which torque converter do you guys recommend, I believe this cars have the th375 transmission does a th 400 torque convert fit? Any help will be appreciated thank you
simpleold is offline
Old June 24th, 2017, 05:18 PM
72Cutlass S
gs72's Avatar
You don't mention your gear ratio. Changing rear end gearing may be a better choice if you are running a high ratio gear set.
gs72 is offline
Old July 1st, 2017, 06:20 PM
simpleold's Avatar
Sorry not very sure about that car is very stock but I don't know exactly gear ratio how would I know?
Old July 3rd, 2017, 05:51 AM
442fanatic's Avatar
Build ticket would indicate. Others on here may chime in with what that model of car typically came from the factory with.
Is it a one wheel burner when you get it to spin out?
If you do rear end gear, may look at limited slip as well.
442fanatic is offline
GINCSC
December 19th, 2015 01:49 PM
Stevec
April 20th, 2012 05:46 AM
Fred H
January 24th, 2008 07:58 PM
SPEEDROCKET
December 18th, 2007 06:35 PM
Surfrat67
May 14th, 2006 03:42 PM
Quick Reply: Torque converter
