1955 Olds Front Wheel Bearings
Old February 9th, 2014, 05:12 PM
Olds Scott's Avatar
Has anyone converted the front wheel bearings from the older ball bearings to the newer roller bearings. I had heard that the 57 Olds bearings can be used with remanufactured races to fit the 55 hub and spindle. One of the upgrades I want to due for safety purposes.
Olds Scott is offline
Old February 9th, 2014, 09:26 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I will be anxious to hear on this one since my 54 still has the ball bearings.
redoldsman is offline
Old February 9th, 2014, 10:03 PM
59-59-59's Avatar
I must be living in a cave, but what 'safety purpose' would that be?? I never had a problem with ball bearings
59-59-59 is offline
Old February 9th, 2014, 10:39 PM
Phantom Phixer
Charlie Jones's Avatar
X2 on this,
Olds designed these bearings to carry several times the load that they will ever carry.
I think the main reason that GM went over to roller bearings was that they were cheaper.
My advice is to clean the bearings thoroghly . Inspect the bearings and races for pitting or rust. if they look good, pack them with good wheel bearing grease and " roll on ".
Charlie Jones is offline
Old February 10th, 2014, 07:11 AM
Although those ball bearings are very expensive, they last a long time if greased and adjusted regularly. I'd leave them alone unless your upgrading to disc.
oldcutlass is offline
Old February 10th, 2014, 08:22 AM
Tedd Thompson's Avatar
Mine is still rolling on the old ones, never had a problem....Tedd
Tedd Thompson is offline
Old February 10th, 2014, 08:48 AM
redoldsman's Avatar
Good to know.
Thanks Tedd
Old February 10th, 2014, 10:01 AM
Olds Scott's Avatar
Sounds like everyone likes the ball bearings. I would still like to run a roller bearing system. Anyone know someone that manufactures a conversion?
Old February 11th, 2014, 01:59 PM
mpolds's Avatar
Ball Bearings vs. taper Bearings......
You guys are on the money with the fact that taper bearings are much cheaper... and there was 1 company that experimented with replacement taper bearings for ball bearing applications -- it was a pretty red, white, and blue box -- called appropriately enough "American" Bearings... unfortunately, they went out of business a long time ago.....
The '55 - '57 Chevy world has "reproduced" their bearings in a taper replacement, but unfortunately, they don't fit Oldsmobiles......
Stay away from these Bearings of today (you guessed it -- china -- and their ***** are held in with plastic cages -- junk.....)
If replacing Ball Bearings -- you must use "NEW OLD STOCK" -- and I do have some, not a lot, for OLDSMOBILES -- 1935 thru 1961 !!!!!!!
Best to call me -- craig -- 516 - 485 - 1935... New York.....
mpolds is offline
Old February 11th, 2014, 02:07 PM
Killian_Mörder's Avatar
...I think the main reason that GM went over to roller bearings was that they were cheaper...
Tapered roller bearings are less sensitive to contamination and the added surface area distributes load. My ball bearings on my '56 Chevy were nothing but trouble. But, I was only 15 when I bought the car and was more interested in partying than in maintenance
Killian_Mörder is offline
Old February 11th, 2014, 03:50 PM
Olds Scott's Avatar
I tend to agree with Killian Morder especially about distributed bearing load. Just got to figure out how to do the conversion.
Old February 12th, 2014, 10:03 AM
Measure the spindle diameters where the ballbearings sat and the distance between both seats. If they match up with another model, you've got it easy. If not, machine accordingly.
Just found this, while looking up spindles: http://www.streetrodderweb.com/featu...8/viewall.html
Old February 14th, 2014, 01:31 PM
pete324rocket's Avatar
Before you buy the outer bearing,check your local bearing shop. Last ones I bought were 20 bucks and change, BO1 sounds familiar, and he said he could supply as many as I needed-for a 56 but similar for earlier. Same goes for all bearings. Remove-take to bearing shop and see what they have on the shelf. Bo1 is the outer and Bo2 is the inner,909001 is outer number fusick uses and 909062 is the inner number.
pete324rocket is offline
cutlass47
Brakes/Hydraulic Systems
19
September 19th, 2012 06:44 PM
oldzy
21
October 18th, 2010 12:17 PM
oldzy
Drivetrain/Differentials
September 14th, 2010 05:40 AM
dantana
May 20th, 2008 12:19 PM
Andrew240
December 22nd, 2007 01:54 PM
Quick Reply: 1955 Olds Front Wheel Bearings
