‘57 Super 88 Radio Removal
Hello. I’m trying to remove the radio so I can get the instrument cluster off of the car in order to finish an upholstery job we’re doing. I’m not having any luck. It’s chrome and I don’t see a set screw so I was just hoping someone could help me figure out how to get this thing off.
Thanks,
Hogan
I removed the panel up until the radio and I can’t get the instrument panel off until the radio piece comes off.
This is the other side of the radio from underneath. I can’t really loosen anything back here and I’m unsure if it’s gonna be alright to unscrew that flathead screw. But it’s the only thing I see that I can do anything with.
Thanks,
Hogan
I don't remember any set screws on the 54 I had. It has little springs inside the **** that put pressure against the shaft. Look real close and if you don't find any set screws, you are going to have to pull them off. I suspect they are almost seized onto the shaft as long as they have been on there. Once the ***** are off, it is a piece of cake like Eric described.
My '55 had set screws and those little spring washers. I am pretty sure those are there to make sure you don't mount the ***** too tight against the secondary ***** for tone and distance. Once you get the ***** off, it will be straightforward to remove the nuts, the chrome faceplate, then the radio stem nuts.
