Spin on adapter (oil)
What Glenn said, easy-peasy direct swap. I still run the canister just because I have a case of filters, but I do have one adapter waiting in the wings when I run out of my shelf stuff... Tedd
I just want to thank all you guys for responding. For something as simple as this might sound, I’m on the younger side of the age demographic and very new to classic Oldsmobiles (made the mistake of thinking GM is GM 🤷♂️) so any help is very much appreciated!
You have come to the right place for help. Some of us old gray haired guys know a little bit and some of the guys know a lot. Oldsmobiles are not Chevys and remember there are no dumb questions. Dumb is not asking a question when you need to. Good luck with your car.
the other user who mentioned having one shows it mounted at a downward 45 degree angle and mine points straight back
This is my oil filter canister mount just above the extended capacity part of my oil pan. Bad pic I know Is it possible to do the swap with the motor still in the car? I have no idea how I would access the bolts that mount it
Well, there is an option. It is the conversion of you current adapter to a spin on filter. I don't like these as much as the later adapter but they work if installed correctly. The will position the filter just like the cannister you now have. Here is one on ebay.
Oil Filter Adapter : Olds Buick Pontiac GMC 49 50 51 52 53 54 55 56 57 58 59 | eBay
jeff.tennis
January 7th, 2023 12:33 AM
