Click Here
new rim and tire size on the cutlass...think this is a good fit?
Old February 22nd, 2012, 11:47 AM
bigjaythe1st's Avatar
I have a 1980 Cutlass Supreme stock suspensionand Im going with ridler 675 17x7 and 17x8. 4.5 bs .Tires are kumho 255/50/17 rear and 225/50/17 front. Do you think I will have any issues and will it look good? thanks a bunch
bigjaythe1st is offline
Old February 22nd, 2012, 01:07 PM
As long as your offset is ok, they should fit!
oldcutlass is online now
Old February 22nd, 2012, 01:18 PM
Well I believe they have a 0 off set but they do have a 4.5 back spacing.Do you think the 225 is wide enough for fronts on the 17x7's?. And 255 on 17x8's wide enough for rear?. Thanks for all the replies and info everyone. its much appreciated
Old February 22nd, 2012, 01:37 PM
The stock wheel has I believe the same backspacing as your new wheels. The OD of your tire is not not bad. I had 275-60-15 on mine and stock backspacing (4.5) and they tucked right in the wheel well in the rear.
I played with this calculator below and plugged in your tire sizes. I think they will look and work fine.
http://www.discounttire.com/dtcs/infoTireMath.dos
L69 equipped
March 19th, 2017 12:31 PM
DANIMAL340
Wheels and Tires
May 25th, 2014 04:50 PM
Nickyloves442s
September 1st, 2013 07:11 PM
oldsguybry
Wheels and Tires
21
February 27th, 2013 08:31 AM
BigAl72
March 16th, 2009 06:16 AM
Quick Reply: new rim and tire size on the cutlass...think this is a good fit?
