advice on Buying a 442
Old September 27th, 2006, 04:15 PM
c1run1's Avatar
Question advice on Buying a 442
Hello ,
is there any info on the 69 olds trim tag or Vin to indicate it's a real car ?
Is the Vin Number on the motor in the same place a chevy would be ?
Anyinformation would be great thanks Joe
c1run1@aol.com
c1run1 is offline
Old October 5th, 2006, 05:18 AM
orange442's Avatar
For a 69 to be a 442 the VIN has to start with 344, the "44" designates it to be a 442. If the VIN does not start with 344 it is NOT a 442. A 69 442 would have a 400(396026-G) motor. To check if the #'s match there is a flat area below the alternator on the block facing the left and it will have a stamping on it. It should read something like 39Mxxxxxx, the 3 is Olds, 9 is 1969, M is Lansing assembly plant, and the last 6 digits should be the same as the last 6 digits in your VIN for matching #'s. Good luck and I hope this helps.
orange442 is offline
Mikesta
March 27th, 2013 06:51 PM
spiderjason
October 7th, 2010 08:00 PM
drfelderjr
August 17th, 2010 06:05 AM
butchashop
June 9th, 2010 08:41 PM
mismith356
December 24th, 2006 02:42 AM
Quick Reply: advice on Buying a 442
