Straight 9006 headlight bulb
Old June 5th, 2010, 03:05 AM
Yellowstatue's Avatar
Just discovered this week that there is a straight 9006 bulb available ....this is to replace the 'El' shaped bulb that is installed in '95 to '99 Auroras ...it is so awkward to change the bulbs through that tiny hole
Yellowstatue is offline
Old June 16th, 2010, 08:19 PM
Dave in MN's Avatar
I replaced the left side low beam headlight on Sunday. Took a few minutes to figure out just 'how' to do it, but it was simple and took maybe 10 minutes once I figured out what I had to take apart to do it.
Dave in MN is offline
Old June 17th, 2010, 03:01 AM
Did you use the straight bulb or the el shaped bulb??
Old June 17th, 2010, 03:20 PM
Dave in MN's Avatar
The el shaped bulb.
805cut
June 8th, 2012 03:15 PM
MHENDERSON
December 11th, 2010 05:37 PM
tim72
April 27th, 2010 05:40 AM
OLD SKL 69
January 2nd, 2009 06:57 AM
1972_442
Brakes/Hydraulic Systems
July 4th, 2008 05:22 PM
Quick Reply: Straight 9006 headlight bulb
