1962 cutlass disc brake conversion
Old December 24th, 2013, 01:12 PM
62 Cutlass Convert's Avatar
Merry Christmas
Has anyone done a Scarebird front disc brake conversion on the 1961-63 Y bodies?
Wondering how the recommended 78-80 Fairmont master cylinder fits and in general how it worked out.
62 Cutlass Convert is offline
Old December 22nd, 2014, 10:02 AM
young olds's Avatar
ive never used one of his kits but have seen threads on people using them. they seem to be good and in the future may use it for disk swap on my 62 f85 wagon. Ive already done a dual res. master cylinder swap on my wagon that worked great. would even be better suited for disk car since that is what it came off. https://classicoldsmobile.com/forums...-cylinder.html check out this link for the info on the master cylinder swap
young olds is online now
Old December 22nd, 2014, 10:29 AM
I checked that out and looks good. I'm going to keep the drum rears and the Fairmont is set up for that. The Fairmont MC is about 7.25 long mounting face to end of nose. Can you take a look when you have time and let me know how long the S10 MC is and is it a Disc/Disc or Drum rear/Disc front MC?
Old December 22nd, 2014, 01:43 PM
young olds's Avatar
the s10 i got it off of was front disk rear drum im pretty sure. s10 went to rear disk in 98 so a 97 or older master should be rear drum if thats what you want. the car is in storage no but if i get by there ill try to remember to measure it.
Old December 22nd, 2014, 05:30 PM
young olds's Avatar
the s10 was approx. 6" from firewall to the other end.
Old December 22nd, 2014, 08:39 PM
young olds's Avatar
I was thinking about the stated approx length of the Fairmont mc. The s10 mc was already a tight fit even after cutting. Any actually use a Fairmont mc on the 61-63 f85?
Old December 23rd, 2014, 12:53 PM
Thanks for the info. This could help a lot. I spent some time yesterday starting to fit the Farimont MC. First thing is the mounting holes are 3.25" on C and the stock MC/ fireall bolts are 3.375" on C, so I need to file out the holes a little to really find out if it will fit. Looks VERY close and I do not want to cut into the channel of the frame. If the S10 is about 6 or even 6.75 it would help a lot. Also thinking since it's a GM MC mounting holes might be right. I gotta take a look at one. I'll let you know.
Old December 23rd, 2014, 01:50 PM
young olds's Avatar
as far as bolting on, it was an exact fit. and its a gm product on your gm, dont know if that means anything to you.
Old December 23rd, 2014, 02:32 PM
Yes it does and it looks great. Was just talking to Marty at Dorman Tech (very helpful guy), it's less bulky than the Fairmont and according to Dorman is about 6.75" will will make the difference in fit to the frame box and the strut coming over. Appreciate the help, thanks!
Old December 23rd, 2014, 10:02 PM
young olds's Avatar
Yeah, hope it all works out
Mocephus
October 1st, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
June 26th, 2013 08:21 AM
ricardo
July 27th, 2010 05:26 AM
Rich
July 10th, 2010 10:39 PM
JCervantes
December 28th, 2008 07:39 PM
Quick Reply: 1962 cutlass disc brake conversion
