61 Olds 88 Front Disc Coversion
Old August 15th, 2012, 09:41 AM
KQQLCAT's Avatar
Has anyone used ABS Power Brake Inc. conversion? I just want to know if there are any issues with turning end to end. They say stock wheels will work with their set up.
Pat
KQQLCAT is offline
Old August 15th, 2012, 10:09 AM
D. Yaros's Avatar
Pat
If you go this route and the stock wheels do work, LET US KNOW! Everything I have read is to the effect that stock wheels will NOT work?
D. Yaros is offline
Old August 15th, 2012, 11:43 AM
Lt. Buzzkill (ret.)
copper128's Avatar
Their listings look suspect to me. They say 12" rotors are included - no way will a 14" wheel fit! Also, they list one part for '65 full-size Olds including J88. Again, no way will a single kit fit both of those (different spindles & wheel bolt pattern). Also, no listing for '66-70, but if it fits '65, it'll fit the rest.
Too many discrepancies, looks like they don't really know much about Olds fitment.
copper128 is offline
Old August 16th, 2012, 04:30 AM
KQQLCAT's Avatar
Here is the reply from them and talks about an offset of 0.
PAT COMPLETE FRONT DISC KIT $575.00 ONLY THE ROTORS ARE ESPECIAL MADE ZERO OFF SET AND ALLOWS THE USE OF YOUR OEM WHEELS THE REST OF THE COMPONENTS ARE ALL AMERICAN .PADS CALIPERS BEARINGS BRAKE HOUSES GREASE SEALS. POWER BOOSTER IS A DIRECT BOLT ON THE FIREWALL.
714-771-6549
LUCIO
KQQLCAT is offline
Old August 16th, 2012, 05:06 AM
That sounds like a cool project. I wish I had some information to give. All I can say is good luck.
Olds64 is offline
Old August 16th, 2012, 08:02 AM
citcapp's Avatar
I do not see how that could work with 14" wheels with taper you can't even get 11" rotors and calipers to fit. My 57 is similar to yours. I would ask them for the outside diameter including the caliper and do your own measurement to verify. I bet you will find that you need 15" wheels. I used the scarbird with 11" rotors and needed to move up to 15" wheels. I did the front and rear disc brake kits because everything is replaceable from Napa or rock auto.
citcapp is offline
Old August 16th, 2012, 11:30 AM
KQQLCAT's Avatar
I will probably go the scarebird route now.
KQQLCAT is offline
Old August 16th, 2012, 11:54 AM
Lalo442's Avatar
I used a kit from these guys on my 69 not sure if they have your application but mine worked with stock 14" wheels
http://www.inlinetube.com/
Lalo442 is offline
RTTOY
17
November 15th, 2020 12:09 PM
64starfire
29
December 5th, 2018 09:08 PM
rhaberm
May 21st, 2013 10:37 AM
oldstata
August 13th, 2012 08:12 PM
xerxes600rr
Drivetrain/Differentials
February 28th, 2010 04:24 PM
Quick Reply: 61 Olds 88 Front Disc Coversion
