Single wire chrome alternator coversion
Old May 20th, 2013, 05:29 PM
rhaberm's Avatar
Has anyone converted stock 3 wire alternator to single wire chrome alternator, 69 cutlass?
Thanks,
bob
rhaberm is offline
Old May 21st, 2013, 06:50 AM
Thanks,
bob
Yeah, lots of folks, who then start complaining that the single wire alternator doesn't charge at idle.
Why do you want to do that? GM didn't install the extra wires just to increase their manufacturing costs. A stock 12SI three wire alternator is EXTREMELY easy to connect to the stock harness - you can even buy a plug-in conversion kit if you have an aversion to soldering irons.
joe_padavano is offline
Old May 21st, 2013, 07:08 AM
lemoldsnut's Avatar
Most of the single wire alternators do not excite or turn on until you get to about 1500 RPM but then do charge at idle. There is a set up that will do one wire and charge at idle. But Joe is right, the 3 wire set up is very reliable and if it goes out on the road you are not hunting for a one wire alternator to replace it.
lemoldsnut is offline
Old May 21st, 2013, 10:37 AM
I converted my alternator to the single wire alternator from Jegs. It was stupid easy to install and I'm very happy with it. I did it because I don't like wires running here and there under my hood (even though I keep everything loomed together with zip ties).
http://www.jegs.com/i/JEGS-Performan...10122/10002/-1
Olds64 is online now
RTTOY
17
November 15th, 2020 12:09 PM
64starfire
29
December 5th, 2018 09:08 PM
KQQLCAT
Brakes/Hydraulic Systems
August 16th, 2012 11:54 AM
oldstata
August 13th, 2012 08:12 PM
Joel
April 12th, 2011 02:58 AM
Quick Reply: Single wire chrome alternator coversion
