alternator problems again
Old May 15th, 2007, 10:00 AM
2 door cut's Avatar
i had recently replaced my alternator. when i had the good alternator in, when i would start my car, the volts would go right to 14 and stay at 14. all of a sudden, my volts dropped to 12.
i had a warranty on it, so i just went and got a new one. i put the new one in and start my car. when the car starts, it stays at 12. ill drive it around, turn the music on, lights on, a/c, etc etc, stays at 12. when im driving, i put it in neutral and rev the **** out of the engine, then it goes to 14 volts, and stays there.
now it stays at 12 until i rev the engine. i asked 2 people about it and they both said that its normal. if this is normal, then why did my old alternator go straight to 14? is my new alternator messed up? could the charging system be screwed?
this is the second or third time ive had problem with my volts, and its getting on my last nerve. almost makes me want to sell this son of a bitch. please help me out becuase im really considering it again.
2 door cut is offline
Old May 15th, 2007, 10:27 AM
Past Administrator
Oldsguy's Avatar
You may not have had to replace the alternator the first time. Did you have it checked first? Most auto parts stores have devices that can check your alternator under a load. Secondly, you haven't mentioned (and may have not looked at) your vehicle wiring and the gauge itself. Either one of those could be causing your perceived trouble. Or, if it is the gauge, then you really don't have a trouble with the alternator or wiring at all.
Oldsguy is offline
Old May 15th, 2007, 10:46 AM
2 door cut's Avatar
but if it was the guage, why would it be doing the exact thing the other alternator (before i replaced it with a good one) was doing?
actually, i know it cant be the gauge becuase my power windows goes up slower when the volts on are 12
Old May 15th, 2007, 05:59 PM
ozoneblue's Avatar
Make shure your belt is tight & not slipping just a little.Does it go around the crank & water pump? or does the PS tension have any effect like the old 350s ?
ozoneblue is offline
Old May 16th, 2007, 04:21 AM
Jim's rare 80
Jim's rare 80's Avatar
Hi. Get a tester, and check the current to the battery when running. Then, disconnect the wire from the back of the alt. start again, and check alt. seperate. This will rule out a wiring issue. jim.
Jim's rare 80 is offline
Old May 17th, 2007, 02:54 PM
2 door cut's Avatar
well, forget about the alternator, cuz my headgasket just blew! yahoo! i curse 2007.
Old May 28th, 2007, 03:35 PM
87candycutty's Avatar
Dude that sucks dont give up on your cuttdog though
worship the cutty even with your hard luck
87candycutty is offline
Old June 10th, 2007, 02:16 PM
dickk's Avatar
94 Cutlass eats alternators
6/10/07
My mother-in-law's 94 Cutlass eats alternators! She bought it new and currently has 40,000 miles and is on the third alternator. The first one died with 2-3000 miles and was replaced by the Olds agency. The second one died with about 20,000 miles and the third one just expired. In each case they have been replaced with factory original equipment. So far the only advice from the agency is just replace it!! The most recent incident was just before entering the freeway -it's getting dangerous. If there's not an obvious fix, it's time to sell the car. Would appreciate any insight others may have. Thanks
dickk is offline
chasman414
June 25th, 2020 07:05 AM
442mark
September 30th, 2017 01:06 PM
76rckt455
December 26th, 2010 10:53 AM
texasred
July 18th, 2008 07:45 AM
Good_Music_n_Cars
October 19th, 2007 08:43 PM
Quick Reply: alternator problems again
