Is this a nodular 8.2 rear end for a 1967 w30 ?
Old December 25th, 2023, 01:35 PM
The Rocket Astronomer
lunaboy's Avatar
Please help Identify this rear end, could it be the rare BOP Nodular rear .
lunaboy is offline
Old December 26th, 2023, 06:09 PM
Looks like it could be a 1971-1972 Buick(?) 8.5” 10 bolt.
Is there a drilled boss on top for the brake hose? Can’t tell definitively from the picture.
Post the entire axle stamping. It looks a lot like the ‘71-later stamping style with the axle ratio code and date.
And what do you mean by “nodular rearend”?
Fun71 is online now
Old December 26th, 2023, 09:03 PM
lunaboy's Avatar
Thanks, it does looks like a 71 buick 8.5 i saw an N on the casting wish i thought was the stronger case and that the 10-bolt that Buick made is a very nice rear,and can take plenty of abuse. "The 71-up 8.5" 10-bolt is just as strong or stronger than a 12-bolt Chevy." so they say?
lunaboy is offline
Old December 26th, 2023, 10:59 PM
monzaz's Avatar
Yep, 10 bolt 8.5 1971 1972 era could be a OLDSMOBILE code as SD is 3.08 in olds too Buick in 1971 is LS and in 1972 it is LSB
SOOO...I AM PUSHING MORE TOWARDS THIS IS AN ORIGINAL 71 72 OLDSMOBILE CUTLASS REAR.
Where is the axle tube code located and is it upside down or right side up with the rear in the car correctly.?
Has 3.08 (13 - 40) gears (thing is the gear set is a 1977 gear set...??? some one was in there...maybe even the posi might not be totally original either...??? )
and a
Original Borg Warner Cone posi.. 28 spline (I think those can be used in c-clip rears and BIA rears. Have to feel the side gears in where the springs are and see if you can feel a recess cut for c-clips.
Watch out those bottom out and then do not do posi after miles are put on them
I have only had a handful after 20 year for 1971 see a unit not need machine work to bring it back.
Only way you can tell is the take it apart and post pics of the cones to see if they rub in the wrong spots.
Jim
JD Race
monzaz is offline
Old December 27th, 2023, 08:23 AM
lunaboy's Avatar
Thanks for your help guys I saw the "N " on the case and thought Nodular.
lunaboy is offline
Old December 28th, 2023, 01:49 PM
monzaz's Avatar
?? Maybe ...Maybe not. Either way it is good housing to build and have. Jim
monzaz is offline
Bigmikey65
May 30th, 2023 03:56 PM
BeenThere
January 7th, 2023 10:32 AM
beefcake
January 12th, 2022 05:49 AM
Olds68swede
Drivetrain/Differentials
January 11th, 2022 01:52 PM
Nickyloves442s
December 29th, 2020 01:55 PM
Quick Reply: Is this a nodular 8.2 rear end for a 1967 w30 ?
