Swapping Pontiac rearend in Olds-Question
Old December 10th, 2010, 06:00 PM
mike623's Avatar
I have a 1979 Firebird formula that has the 3.42 posi. Can it be swapped into my 1972 Cutlass? I know the firebird has the leaf springs and the cutlass has the coils under it. Someone told me that I could change that. Other than that would the rearend work?
Thanks, Mike
mike623 is offline
Old December 11th, 2010, 12:18 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
I think they are about the same width.
The different pumpkin is where you may have problems.
Measure the housings from the pinion yoke to the back side, and see if your driveshaft will still work before you go crazy with the welder. Conversion u joint may be needed in the rear as well.
Personally, I'd rather have the 72 bolt in axles than the metric C clip axles.
If they're both 8.5 rears, you can swap the guts, and keep your bolt in axles.
J-(Chicago) is offline
Old December 11th, 2010, 01:30 AM
svnt442's Avatar
I'm with J on this. Swap the guts and keep your housing. It's not worth the money to convert a leaf spring axle for control arms.
svnt442 is offline
Old December 12th, 2010, 07:20 AM
507OLDS's Avatar
The leaf-spring housing won't have the upper ears cast into it for the upper conrol arms. Just swap the guts,but get all of the specs on the gears before you remove them,so you can make sure they are the same when you swap into the other housing.Run some compound on them tto see what the current pattern is.As long as it is a good working rear,the pattern should be good.You will need to achieve this same pattern when they get swapped into the other housing.
507OLDS is offline
stressed1
December 12th, 2012 01:15 PM
godson
January 3rd, 2009 06:06 PM
59-59-59
April 16th, 2008 09:13 PM
dhoopty
Drivetrain/Differentials
April 16th, 2008 09:45 AM
oldstay
March 6th, 2008 02:48 PM
Quick Reply: Swapping Pontiac rearend in Olds-Question
