U-Joints
#41
The clip doesn't go INTO the hole in the yoke, it goes AGAINST the hole in the yoke to prevent the cap from getting pushed all the way out the other side. Once you get one side's clip bottomed out against the inside of the yoke, you should have room to install the opposite side cap from the outside onto the U-joint and seat it deep enough to get the clip installed on that side. Once both clips are in, the U-joint and caps are captive within the yoke and cannot come loose.
#42
#43
I'm sure glad someone pointed out the clip doesn't go inside the groove on the yoke, just on the cap so it can't push outwards . Thank God , now the other side .... Thanks for everyone's help
#45
#46
The ones without the grease fittings are supposed to be greased for life with no maintenance. They are also less prone to cracking at the grease fitting and preferred for racing applications. They say that the ones with grease fittings should be greased every 5k miles, I've never understood that since the ones without the grease fittings tend to hold the same amount of grease.
#48
I still do not know where the heck you were trying to install the c-clip for the u joint cap. The picture is correct...BUT where the heck were you trying to get it into that you thought it would not fit...Like in the rubber seal area where the cap meet the cross shaft? ALL this for??? LOL
ALL four caps work the same exact way. Clips in the same spots. I is a square u joint .
JD
Jim
JD
Jim
#49
JD
Jim
JD
Jim
#50
Apologies for not mentioning where the clips go in earlier posts but I “assumed” you were familiar with that and just needed info on how to get the originals out of the injected plastic.
Well anyway now you’re an expert in u-joint removal and installation. Good job.
cluelesscutlass
August 18th, 2011 01:56 AM
