Oil and water temp sending unit wires
Old March 12th, 2024, 02:02 PM
beebee78's Avatar
Can I run two new wires for thes sending units as they are missing and if so where and what color do they connect too ? As I’m installing Ralley pack gauges but missing the wires under the hood ? Thanks
beebee78 is offline
Old March 12th, 2024, 02:25 PM
The blue and green wires were in the factory harness originally. They are the same wires used by the idiot lights. These wires are in the engine harness part of the firewall connector.
joe_padavano is offline
Old March 12th, 2024, 02:49 PM
Series 56 male terminals. You can get them at Napa pretty cheap.
Take a closer look at the firewall connector. Unless someone took the time to remove the connector body and remove the wires from the housing, I bet they are there. Unless the cut them flush with the housing?
matt69olds is offline
Old March 12th, 2024, 02:50 PM
beebee78's Avatar
Thanks Joe,
as soon as I posted this I was tugging on a blue and green wire and
they both came out of the firewall capped off and ready to go right where I left them about 10 years ago lol 🤣😂🤣 thanks for the quick response !
beebee78 is offline
Old March 12th, 2024, 02:51 PM
beebee78's Avatar
They were there right where I left them 🤣😂🤣
beebee78 is offline
wherlehy
May 2nd, 2021 04:58 PM
69442murph
July 14th, 2014 10:52 AM
boondocker
August 22nd, 2011 10:03 AM
texasred
July 31st, 2007 10:18 AM
<mr.stew@netzero.net>
October 18th, 2004 11:20 AM
Quick Reply: Oil and water temp sending unit wires
