is a stock '67 olds 442 "P" type rearend exactly the same diff used on '66 '67 GTO's?
Old March 9th, 2014, 01:43 PM
Tastefully Hooped
L77F85's Avatar
hi all can anyone tell me if the stock '67 olds 442 "P" type differential housing the same diff used on '66 '67 GTO's?
thanks
L77F85 is offline
Old March 9th, 2014, 02:05 PM
66-3X2 442's Avatar
thanks
Yes,it's the one and the same. They did however use different ID codes.
66-3X2 442 is online now
Old March 9th, 2014, 03:35 PM
Tastefully Hooped
L77F85's Avatar
Originally Posted by 66-3x2 442
yes,it's the one and the same. They did however use different id codes.
thank you
L77F85 is offline
Old March 9th, 2014, 04:36 PM
Trying to remember member
wmachine's Avatar
I know at least some of Pontiac center housings have a large letter N on the front top of the housing signifying a nodular iron housing. Supposedly a stronger housing, but I don't believe the cast iron versions were ever a problem for strength. So I wouldn't think that was significant. I believe all of the internals are the same.
wmachine is offline
Old March 9th, 2014, 04:49 PM
66-3X2 442's Avatar
Actually the B or P axles had the same internals. The difference being the P axle had the additional converging reinforcing rib the B axle didn't. As far as the N goes,I hadn't noticed it on the P axles I've had and don't really know if I've ever had a P axle with a Pontiac ID stamped code.
Octania
July 8th, 2021 10:24 PM
HitTheHole
Drivetrain/Differentials
February 4th, 2021 10:46 AM
L77F85
16
November 29th, 2013 06:19 AM
lil_no
May 10th, 2012 09:58 AM
1BAD68"S"
December 29th, 2007 09:05 PM
Quick Reply: is a stock '67 olds 442 "P" type rearend exactly the same diff used on '66 '67 GTO's?
