Will 1968 Cutlass Column Shift Steering columns from 2 spd or 3 spd interchange
Old March 23rd, 2013, 04:50 PM
2blu442's Avatar
I think I squeezed the whole question into the title! I know the floor shifters have different detents. But am not sure if a 2 speed column could be used in a 3 speed swap without changing something in the column like the detent. Can anybody shed some light on this one?
John
2blu442 is online now
Old March 23rd, 2013, 05:26 PM
You can use the 2 spd column with a 3 speed trans. It will get all gears, just that drive will be just a bit over and there will be no mark(unless you change the indicator) for second gear.
oldcutlass is online now
Old March 23rd, 2013, 05:53 PM
2blu442's Avatar
Thanks for the quick response!
John
Old March 24th, 2013, 09:14 AM
The problem with using a 2 spd detent on a 3 spd trans is that you won't get the proper detent alignment, obviously. You have to be very careful when you shift to feel the detent pop into place in the trans, and you run the risk of bumping the shift lever (or just road vibration), causing the trans lever to move. With the column and trans detent locations fighting each other, it's possible for the trans detent to be in between gears, not a desirable condition.
joe_padavano is offline
Old March 24th, 2013, 09:47 AM
Joe, I run a T400 on my 2spd column. The detents lock in place and the only issue is second gear is between L and D obviously. There is no chance of it dropping out of gear due to any reason other than me moving it there. The column determines where park and neutral are, the trans determine the rest.
starfire
December 9th, 2021 08:21 PM
317Cutty
June 18th, 2014 10:53 AM
brandon reynolds
November 26th, 2013 02:24 PM
Rocketbrian
October 2nd, 2013 10:18 AM
Bitburger
December 30th, 2012 04:49 PM
Quick Reply: Will 1968 Cutlass Column Shift Steering columns from 2 spd or 3 spd interchange
