Reading a VIN
Old February 4th, 2012, 05:28 AM
BHoene's Avatar
Reading a VIN
Can anybody give me a brief tutorial in reading a 74 VIN? I have the numbers and need some help. I have looked on-line but am a bit confussed. Thanks
3G37V4M310175
BHoene is offline
Old February 4th, 2012, 05:37 AM
Blackpage's Avatar
Go here: http://v8cars.hu/oldsvin/decode.php
Blackpage is offline
Old February 4th, 2012, 06:06 AM
TSMITH75's Avatar
how far back will that site decode
TSMITH75 is offline
Old February 4th, 2012, 06:07 AM
Lansing built
1970cs's Avatar
adding to
V=455 4bbl according to GM dealerworld see foot note for division/make
http://service.gm.com/dealerworld/vi.../vincard74.pdf
Pat
1970cs is online now
Old February 4th, 2012, 06:22 AM
vette442's Avatar
It says 1946 right at the top.
Is your car a Hurst/Olds? That's a common application for the somewhat hotter V code 455/TH400 combination of 1974.
Terry
vette442 is offline
Old February 4th, 2012, 06:29 AM
jaunty75's Avatar
Here's another site with VIN decoding info for all GM going back to 1972.
http://service.gm.com/dealerworld/vincards/
jaunty75 is offline
Old February 4th, 2012, 07:43 AM
BHoene's Avatar
Thumbs up Vin
Thanks for all the help this morning. Yep, it is a 74 Hurst 455.
BHoene is offline
Old February 4th, 2012, 10:50 AM
BHoene's Avatar
follow-up question / Parts Supplier
Can you recommend a good place to get parts, emblems, etc for a 74 Hurst?
BHoene is offline
Old February 4th, 2012, 10:54 AM
jaunty75's Avatar
The post-1972 Cutlasses aren't as well supported by any means as the earlier Cutlasses. Several vendors cater to the Olds hobby, including Fusick, Year One, and Kanter, with Fusick devoted exclusively to Oldsmobile. Most, though, will have engine, brake, drivetrain, etc.-type parts. Body and trim will likely have to come from donor cars.
One place you'll likely run into people facing the exact issues you are is over at the '73-'77 Oldsmobile forum. If anyone does, people there ought to know about the best sources of parts for a car like yours.
http://www.73-77olds.com/
jaunty75 is offline
Old July 23rd, 2012, 07:01 PM
rhurstolds74's Avatar
Emblems and stripe kits are readily available through multiple Olds catalogs. NOS seat material is at SMS in Oregon (?). Interior plastic is mostly used only with the exception of lower door panels. Body parts are used only, with the exception of floor pans, and mediocre quality quarter panels.
rhurstolds74 is offline
justagirlfromla
March 27th, 2010 11:49 AM
71cutlasssx
December 20th, 2009 07:19 PM
Tony Cutlass
November 25th, 2009 05:38 PM
The Stickman
November 30th, 2008 05:20 PM
bulldog
May 19th, 2008 01:29 PM
Quick Reply: Reading a VIN
