1969 Cutlass Flat Top Wagon 3 speed Manual
#81
I often give them Horace Greeley's advice.
" Go west, young man, go west. "
#82
Made some progress this weekend. First, the rear axle seals looked a little wet, so I pulled the axles. One bearing was rough, so both went off to the machine shop for new bearings. I had bought these toggle bearing/seal pullers, but the thread doesn't fit on my slide hammer. It does fit on my balancer installer, and by using part of coil spring compressor tool as a spreader, I put together a seal puller.
Normally I just use the right size socket to drive seals in place, but my closest 3/4 drive socket was too close to the edge of that raised portion inside the seal. I remembered a box of exhaust pipe adapters that had come with a bunch of other stuff I had bought at an auction, and there was a perfect piece to use as a driver.
The front e-brake cable was frayed where it had been routed incorrectly under (vs over) the crossmember. I figured I MIGHTASWELL replace all the cables (it's an MT car, I'll be using the e-brake). Surprisingly, all but one of the bolts holding the inner fender to the wheel opening lip came out, so I only needed the cutoff wheel for one of them. New clip nut and bolt solved that problem, along with a generous helping of anti-sieze. The pawl on the e-brake pedal was stuck, so I also had to pull the pedal and liberally lubricate the pawl to free it up. And while they don't show in the photos, the back KYBs are also installed now.
#86
Joe, I have had the same experience, you forgot no penetrating oil required. One car I worked on, I thought I could have disassemble the entire car with a 3/8 drive ratchet. Your making good progress.
Delmont 88 425
March 11th, 2024 09:51 AM
