70 cutlass supreme convertible my first frame off
#82
Got the inner patch installed still a bunch of pinholes I keep blowing through some of holes making them worse.
went back with a copper backing got the large holes filled not sure if it's worth trying to patch those little holes.. I made a bunch of little holes into large ones.
#86
Decided to take a shot at filling some holes on the windshield frame.
A lot of patience and grinding I managed to fill a couple holes
Found a better way, make a little patch, shape and hold it with a coat hanger
Getting ready for the next one
#91
#93
Looks good.. The welding is coming along.. The other day I tried a change on the settings on the mig. I turned the heat down and slowed the wire feed down.. I was shocked at how nicely the weld came out. I was actually able to control the puddle better that way. Give it a try and see what happens..
I hope it helps!
I hope it helps!
#94
Started patching the wheel wells.
Started with a big patch making it easier to form
ended up with just a small portion of the original patch
I left the edge of cut piece attached to help with aligning the contour of the patch
welded the inside edge
Filled a couple holes on the other side
#96
We managed to get the patch tucked between the brace and the old floor and peeled back the side.
Not sure if that's the right way but should be a lot stronger than a butt weld. (Is this overkill?)
#101
Got an hour to sneak out to the garage more welds on the floor pan.
Got an 80 cf tank so I don't run out every time I turn around.
Turned up the gas flow a bit and I think my welds are finally coming around.
#109
Waiting for the 18 gauge I moved on to repairing the floor brace.
Going to wait for the nice weather tomorrow so I can open the doors and put a fan on while welding the galvanized area
#114
Been busy... going to try and catch up.
Got a bunch of parts a GTO was getting upgraded to a Ford 9 inch with a Tremec 5 speed so I got a good deal on recently removed parts. With about 50 miles on them.
3.55 posi
3.55 posi
#119
WOW, you are doing a lot of amazing work. I would suggest playing with the amperage and wire speed. It should run a nice continuous bead, sounding like bacon crackling. It looks like it's sputtering, either a little less wire speed or a bit more amperage. I'm happy to see you found this car to work on, the rust bucket would have been a crazy amount of work. Looking forward to seeing your progress!!!
Steve
Steve
#120
Steve
Steve
I still have old red and acquired almost everything I need to make two.
This one is turning out to be a 1000 piece puzzle, the other might be easier by replacing a small number of large pieces vs all the small pieces as I am doing with this one
