prep for paint
Old February 7th, 2012, 12:48 AM
72cutlassolds's Avatar
prep for paint
about to do my own body work and prep for paint should i grind off all the paint and primer on the car to bare metal or just close to it
72cutlassolds is offline
Old February 7th, 2012, 03:42 AM
Registered
Bluevista's Avatar
It's best to go to bare metal, it really isn't much more work and you'll have a much better base for the primer. I like the two part epoxy primers, just don't use rattle can lacquer based primer.
Bluevista is offline
Old February 7th, 2012, 06:30 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I would not recommend grinding the old paint off. You will scar the sheet metal and create a lot more work trying to get it smooth again. If the car has ever been repainted you definitely need to take it down to bare metal. A lot of people are using soda blasting. I have never used it. Then you can always use chemical paint stripper. It is messy and you have to have plenty of ventilation. I have done several and it is not fun. If you do this, be sure and use aircraft stripper. I see you are in CA. I don't know if you can even buy this stuff in CA.
redoldsman is offline
Old February 7th, 2012, 06:43 AM
@redoldsman yeah its been painted a few times i think because i can see where body filler was used on sertain parts of the car and yes we carry aircraft paint remover here i used it several times before @bluevista ok i will look for that kind of primer thanks for you guys info.
Old February 7th, 2012, 04:12 PM
fourtwenty's Avatar
We use sharp scrapers to remove the old paint to metal. No fumes and no dust. Once you get an edge going it actually peels pretty good.
fourtwenty is offline
Old February 7th, 2012, 04:56 PM
ziff396's Avatar
I took mine to bare metal. A combination of sanding, grinding, and stripper. Man, that original coating on the metal can be a bear! Needless to say, some was left. I then coated everything with epoxy.
ziff396 is offline
Old February 7th, 2012, 05:00 PM
thanks for the info i think i wanna go bare metal also paint goes on more cleaner looking dont think a sharp scrapper will work for mine cause the whole car is primered and who knows whats under neith
Old February 7th, 2012, 05:02 PM
allyolds68's Avatar
I stripped my whole car with wires wheels, lots of them
allyolds68 is offline
Old February 7th, 2012, 05:07 PM
will the wire wheels work good on this primer it looks like a prety thick coat ? i was thinking a grinding disk
Old February 7th, 2012, 05:09 PM
4424me's Avatar
the 3M roloc scotchbrite disc things work good. but they are expensive.
4424me is offline
allyolds68's Avatar
Like was said previously, don't use a grinder. It leaves a mess in the metal. A course wire wheel cuts through paint fairly easy and doesn't mar the metal, it's the bondo that slows you down.
Old February 7th, 2012, 05:12 PM
golds56's Avatar
I tried aircraft stripper and dads sprayable,ended up useing 80 and 150 grit sand paper on a 9" da(mudhog ) and then a vacume blaster in the impossible to get at areas with black beauty blasting abrasive.Evercoat slicksand epoxy primer over DP50 sealer then dp50 again in the booth to seal the primer and keep it from shrinking.Dont grind except where you will be useing filler or patch panels ,it will heat the metal and couse it to expand making it difficult to get straight body work.
golds56 is offline
1971viking
Paint
May 24th, 2012 07:22 AM
Del70
May 22nd, 2011 01:31 PM
Ranzan
March 17th, 2011 08:09 AM
nonhog
September 1st, 2010 08:44 AM
Doug69Cutlass
May 7th, 2009 06:56 PM
Quick Reply: prep for paint
