Good quality direct fit radiator suggestions for 77-84 98?
I noticed when I pulled it out that the original radiator had sprung a leak at some point. I've done some searching, there are certainly aftermarket options available from places like Summit and Champion that say they will fit, but I've also read a lot of very negative reviews about bad quality. I've searched the forum here and found a number of glowing reviews for US Radiator and Cold Case. Unfortunately US Radiator's 98 offerings only go up to '76, clearly meant for the previous generation and Cold Case only seems to offer them for A bodies. Can either of these be made to work? I've also seen it suggested to have the original rebuilt, I just don't know which shops are good. I've had a lot of experience with bad shops of other kinds so unless they have a good reputation that isn't really a bulletproof solution either.
I was able to get a direct fit replacement for the 78 Custom Cruiser thru Auto Zone several years ago, which should be the same as your car. Granted, it was aluminum core with plastic tanks, and generic to all GM B and C body cars but it fit and worked well.
I recommend NOT shopping at your local auto parts store. I have a cheapy from O'Reilly Auto Parts in my 71 98 and it's on my list to eventually replace. It's a generic aluminum and plastic radiator that is designed for multiple applications. No doubt it's sized just big enough to keep the 455 from overheating. There's even a secondary exhaust port below the radiator cap that's blocked with a rubber nipple and hose clamp.
I just ordered an aluminum replacement for my 62 from Ebay, Focus Cooling.
Ebay guarantees it to fit. I'm pretty sure it won't without modification to the saddles but all other dimensions are exact match.
For the price if it works a few years it's a deal.
This will give me time to have my original recored once I get the funds.
I'm skeptical of the quality but we will see.
Speaking of which I do actually have an update, on a whim I decided email US Radiator to just to see.....and it turns out they do have radiators that seem to be the right size. I was directed to part number 008318ANN, and they have a few options that don't have the heater hose connector. This is a promising lead and I'm still following through for the specific version that's the right fit, but so far so good. I think there's a path forward with them.
US Radiator does indeed have the right sized ones, for the 98 it's the Modine 530. When placing the order by phone I discovered they could make it to be exactly like what I have, complete with a spot for a low coolant sensor and also not having a heater connection. They're still working on the order but so far so good. I also emailed pics to their sales people to make sure it's what I need. I opted for the high efficiency upgrade, figured extra cooling with a 403 won't hurt so it will perform even better than the one I have now.
Here's a link.
https://usradiator.com/
I'm surprised they have copper and brass radiators available. Did you order a copper and brass or aluminum radiator?
Here's a link.
SirVelociraptor
May 27th, 2024 07:37 AM
