Camshaft advise
Camshaft advise
I restored a 1970 Cutlass S a number of years ago and I now need to replace the camshaft and lifters.
The engine is a Chevy BB 454. Yeah, you can bitch at me later, not being an Olds engine, but it was in the car when I bought it. My problem is it's a street show car and I just want to put a stock cam in it and I can not find the stock cam specs. I do not want anything radical as I am not wanting to gain any power or anything, I just want it to run smooth and quiet at idle and not overheat in normal driving.
The research I have done have got me here:
Lobe separation: - 112 deg to 118 deg
Lift under - .550" (I'm assuming mils)
Duration - under 230 deg
Out of all the research I have done I still don't understand the difference between duration and advertised duration. Any help there will be appreciated. This coming from a retired Engineer.
Any help would be greatly appreciated
Send a pm to Vortecpro, link below.
ClassicOldsmobile.com - View Profile: VORTECPRO
I'd talk to Summit Racing, Speedway or even Lunati or Comp Cams directly and tell them what you want and they will find the cam that is right for you. The BBC platform was around for a long time and a ton of research was done. Perhaps they can find one for you that increases efficiency yet doesn't shake your teeth at idle.
Or just ask them for something stock, of course.
Howards has a lot of small cams listed , even some that are directly spec to stock cams, and you can buy them very reasonably priced at Competition Products. Go to the Howards website and check out their warrantied cams.
That said I would be more likely to prefer one of the small Voodoo cams by Lunati to anything else currently being made in an "off the shelf" cam.
I'd purchase the lifters from either Mike Jones or Chris Straub , of course you can also buy a cam from them too, it will be higher priced but tailored to your specific application.
My first 442 (in 1978) came with a lo-po sbc 350 and it got yanked and a '66 bbc 396 installed, that also got a Crane solid lifter cam and we proceeded to wreak havoc 'n break shyt !
