Olds 350 engine, 395558 with #5 heads, NE TN.
Old July 1st, 2023, 02:54 PM
65Delta's Avatar
This is the original, numbers matching engine from my '69 Cutlass S. It had a 2bbl intake and I swapped to a 4bbl in 2015. I pulled this engine in December 2021 and it's been stored indoors since that time. The engine ran well but used a lot of oil, specifically in cylinder 7. In my opinion it's the perfect candidate for a rebuild and, if my car was100% original, I'd have done just that. I sourced a 73 block so she wouldn't be down for an extended period of time. The distributor, thermostat housing, and vacuum switch in the engine are from the '73 and are only there to keep debris out. $400.
Link to video of it running right before I pulled the engine:
65Delta is offline
Old July 8th, 2023, 10:55 AM
65Delta's Avatar
I realized that I'd forgotten to list mileage. Odometer had 4,485 when the engine was removed. I'll say 104,485 but could be 204,485.
65Delta is offline
Old August 9th, 2023, 05:29 PM
65Delta's Avatar
bump
65Delta is offline
Old September 9th, 2023, 06:20 AM
65Delta's Avatar
bump
65Delta is offline
Old October 11th, 2023, 04:54 PM
65Delta's Avatar
bump. Now $500 obo
65Delta is offline
Old November 13th, 2023, 07:20 PM
65Delta's Avatar
bump
65Delta is offline
Old December 17th, 2023, 06:02 PM
65Delta's Avatar
Bump. Now $450 obo.
65Delta is offline
Old January 18th, 2024, 07:22 PM
65Delta's Avatar
Bump.
65Delta is offline
Old January 19th, 2024, 02:40 PM
No it's not a parts car!!
Schne442's Avatar
Where are you located?
might make it easier to sell if it can be picked up or if it would need shipping
Schne442 is offline
Old January 19th, 2024, 04:27 PM
65Delta's Avatar
Good point. NE TN isn't very specific. Johnson City TN area, not far from either I-81 or I-26.
Local pickup is best. I have a cherry picker and can load the engine in a pickup, trailer, etc. Shipping is possible but would require a lot of research & some kind of pallet.
65Delta is offline
Old February 23rd, 2024, 03:52 PM
65Delta's Avatar
Bump. Now $425
65Delta is offline
Old April 28th, 2024, 10:10 AM
65Delta's Avatar
Bump. Now $400
65Delta is offline
Old May 31st, 2024, 04:19 PM
65Delta's Avatar
Bump.
65Delta is offline
ron.bruce85@gmail.com
January 21st, 2023 06:06 AM
alchargo
October 21st, 2021 01:58 PM
ericisback
October 21st, 2021 06:20 AM
JkWheels
April 10th, 2021 03:23 AM
68oldscutlass
January 21st, 2014 10:38 PM
Quick Reply: Olds 350 engine, 395558 with #5 heads, NE TN.
