434 ci DX build
Old December 8th, 2023, 07:19 AM
cutlassefi's Avatar
434 ci DX build
Here you go;
DX block
My DX 4.00” Stroker crank
Mahle 4.155 pistons, 10.5:1
Lunati 6.125 rods
Custom hyd roller
BAM .937 solid roller lifters
CNC’d Speedmasters (Early version)
Victor cleaned up by Wilson manifolds
My 1.7/1.65 HS rockers
Holley Terminator TBI
587hp/540tq
cutlassefi is online now
Old December 8th, 2023, 07:38 AM
Stuck in the 80's
SteveDB's Avatar
Mark,
Always great to see your builds and results. Appreciate you continuing to share.
SteveDB is offline
Old December 8th, 2023, 11:55 AM
Gary
VC455's Avatar
Mark,
Beyond the prodigious power...
That's a gorgeous build! Nice workmanship and attention to detail.
Cheers,
Gary
VC455 is online now
Old December 8th, 2023, 11:57 AM
therobski's Avatar
Sweet Mark, now let's wait and see where it will be planted!
therobski is offline
Old December 8th, 2023, 12:23 PM
Rallye469's Avatar
Nice!
Have the sheet? I'd love to see the curve on this thing
Rallye469 is offline
Old December 8th, 2023, 01:10 PM
Bernhard's Avatar
Nice Build.
Bernhard is offline
Old December 8th, 2023, 02:12 PM
cutlassefi's Avatar
Thanks guys!
’69 Cutlass with a 4 speed and 3.91 rear.
Old December 8th, 2023, 02:45 PM
oldsmoboogie's Avatar
Nice work!
oldsmoboogie is offline
Old December 8th, 2023, 02:47 PM
Man, the torque curve looks like Kansas. Awesome!
joe_padavano is offline
Old December 9th, 2023, 04:06 PM
JohnnyBs68S's Avatar
I'm just a drooling, here. Nice work.
JohnnyBs68S is offline
Old December 9th, 2023, 08:52 PM
oldsfromyell's Avatar
That'll be an absolute blast in a clutch car. Great job Mark
oldsfromyell is offline
Old December 11th, 2023, 05:25 AM
oddball's Avatar
Mark, as expected, the torque curve on my 440 looks almost the same from 3900 to 5000, but the mine starts falling off at 5,100 due to the Performer RPM.
What's the 0.050" numbers on those lobes?
How is the Terminator TBI working out? I just ran a 2 barrel Sniper 2 on a straight 6 in a '65 C10 and, once we got the original distributor to work correctly, ran really really well. Much better than the ongoing battle with a first gen MSD Atomic TBI on a mild SBC. Hilariously, that 2 barrel Sniper has a "cam" configuration screen with only one option: "Stock/mild". Very presumptuous of them, I think.
oddball is offline
Old December 11th, 2023, 06:27 AM
KCTexan's Avatar
Going to "dog ear" this post for my '69 DX "some day" build!
KCTexan is online now
Old December 11th, 2023, 08:21 AM
cutlassefi's Avatar
Originally Posted by oddball
What are the 0.050" numbers on those lobes?
With the big lifters it comes out to 246/254@.050.
Terminator is probably the best of the worst. As you know I don’t regard TBI units as “fuel injection”. But these work ok. You just need to really limit the learn almost immediately after getting a base map, and do the rest yourself. Otherwise, they don’t repeat very well pull to pull.
Old December 12th, 2023, 06:10 AM
oddball's Avatar
Ah, almost an extra 10 degrees on that cam. What's the intended use of the engine?
oddball is offline
Old December 12th, 2023, 06:28 AM
deadeyejedi's Avatar
This is the motor I want 👍 and love that it’s spinning at 6000 rpm’s and making power . Nice work , maybe someday
deadeyejedi is offline
Old December 12th, 2023, 06:43 AM
cutlassefi's Avatar
Fun😉
Old December 12th, 2023, 09:58 AM
fleming442's Avatar
But, it's all done at 6k, too
fleming442 is offline
Old December 12th, 2023, 10:07 AM
True ! but still all I would need my ***** are a lot smaller than they used to be 😳
Old December 12th, 2023, 10:14 AM
Sugar Bear's Avatar
Mark,
WOW, very nice!
​​​​​​Please consider posting a video and audio clip of one of these builds. I'd like to play it very loudly in my daily driver...it would be kind of like "make believe" performance. 😬
Sugar Bear is offline
Old December 12th, 2023, 11:20 AM
cutlassefi's Avatar
Mark,
WOW, very nice!
Lol!
Bruce, actually the Dyno sheet posted doesn’t really give the whole story. It was still making in the 580’s around 6200. (Never look at the first and last number as being correct). I’d say a redline of 6600 or so would prove to be optimum.
Old December 12th, 2023, 12:04 PM
chadman's Avatar
That's a nice build!
chadman is offline
Old December 12th, 2023, 01:58 PM
cutlassefi's Avatar
Thanks Chad!!
Old December 27th, 2023, 03:28 AM
rkk69olds's Avatar
This beauty is mine!. Mark did my 455 build so I knew this one would be fun. Going in my 69 Cutlass Convertible with a TH400 from JW Performance and 3.91 12 bolt from Brian Trick.
rkk69olds is offline
Old December 27th, 2023, 04:57 PM
Fpcopo's Avatar
I wish I had known about those lifters when you helped me with my build Mark. Do they have those .937s available in hydraulic?
Fpcopo is offline
Old December 28th, 2023, 06:33 AM
oddball's Avatar
BAM only makes solid lifters. Sure, setting the lash on a hydraulic cam is a bit tricky (you want close to zero but not zero when cold), but at least for me it's not any noisier than it was with hydraulic lifters.
oddball is offline
Old December 28th, 2023, 07:31 AM
cutlassefi's Avatar
Old December 28th, 2023, 07:49 AM
Fpcopo's Avatar
Thanks. I went to their website and it didn’t say anything about hydraulics.
Fpcopo is offline
cutlassefi
January 18th, 2024 12:00 PM
oldsmoboogie
July 3rd, 2023 09:14 AM
cutlassefi
November 24th, 2022 06:45 AM
cutlassefi
April 25th, 2021 10:50 AM
Bernhard
November 22nd, 2012 07:12 PM
Quick Reply: 434 ci DX build
