434 ci DX build
434 ci DX build
Here you go;
DX block
My DX 4.00” Stroker crank
Mahle 4.155 pistons, 10.5:1
Lunati 6.125 rods
Custom hyd roller
BAM .937 solid roller lifters
CNC’d Speedmasters (Early version)
Victor cleaned up by Wilson manifolds
My 1.7/1.65 HS rockers
Holley Terminator TBI
587hp/540tq
DX block
Lunati 6.125 rods
Custom hyd roller
587hp/540tq
Mark, as expected, the torque curve on my 440 looks almost the same from 3900 to 5000, but the mine starts falling off at 5,100 due to the Performer RPM.
What's the 0.050" numbers on those lobes?
How is the Terminator TBI working out? I just ran a 2 barrel Sniper 2 on a straight 6 in a '65 C10 and, once we got the original distributor to work correctly, ran really really well. Much better than the ongoing battle with a first gen MSD Atomic TBI on a mild SBC. Hilariously, that 2 barrel Sniper has a "cam" configuration screen with only one option: "Stock/mild". Very presumptuous of them, I think.
Terminator is probably the best of the worst. As you know I don’t regard TBI units as “fuel injection”. But these work ok. You just need to really limit the learn almost immediately after getting a base map, and do the rest yourself. Otherwise, they don’t repeat very well pull to pull.
Bruce, actually the Dyno sheet posted doesn’t really give the whole story. It was still making in the 580’s around 6200. (Never look at the first and last number as being correct). I’d say a redline of 6600 or so would prove to be optimum.
BAM only makes solid lifters. Sure, setting the lash on a hydraulic cam is a bit tricky (you want close to zero but not zero when cold), but at least for me it's not any noisier than it was with hydraulic lifters.
Thanks. I went to their website and it didn’t say anything about hydraulics.
