529 Olds build
#122
Chassis sure is working well !! You can have all the power in the world but it won't get you anywhere unless your chassis is tuned just right, and man does this thing hook and book!
The best part? REAL OLDS POWER - not just some big block Chevy as usual.
Keep up the good work! Before we know it, you will have it tuned in even further still!
#123
Chad, a couple questions concerning the mandrel...
Did you have to do any machining on the crank mandrel to fit the ATI damper?
Is it mounted in a hub centric or bolt centric configuration ?
Thanks,
Josh
Thanks,
Josh
#124
I had to take a light cut on the I.D. of the mandrel where it locates on the ATI damper. I'm talking maybe .002-.003, don't remember exactly. It is hub centric.
#129
This gutless turd again! Pretty sure my build makes those same numbers. Just in a different order like 139 HP...😃 Your build and car are definitely a high water mark in the Olds community.
