CNC Ported Edelbrock Heads
#81
Excellent info there for the valve to bowl ratio on the exhaust, thanks!
I think we could have improved the flow curve on the intake side in the low to mid lift areas with the bigger valve, but I believe they ended up going in the 330’s at .750 lift (with a 4.155 sleeve in the SF600 flow bench)on the final test that Vortecpro did.
They didn’t stall, from what I understand.
#84
#85
No reason then. I personally would want before and after numbers to study and estimate the power curve. If you are happy, I am happy for you.
#86
if nothing else I think it would be nice to have a reference as to how much lift to put in it. But I understand. Just sayin.
#88
#89
#90
I've never even seen a flow bench in person. I see "flow numbers" based on the opening of a valve at, what appear to be, cam lift numbers. I can only assume that the valve is stationary at said "cam lift". It doesn't move the valve to simulate a running engine, thus negating any measurement of the effects of reversion......
#91
Flow number is not everything. Shape and size of the combustion chamber. I think is a big factor also. Look at Chad's custom CP piston, Marcella custom intake for example. Other factors like his valve sizes ratio. Using what you have in flow to it maximum efficiency makes power. Bill just has so many years of experience. He knows it just not all about the flow numbers.
#92
And yes flow quality means something as well. Some lesser flowing heads can make the same power as “better” ones.
#93
Say what ??? Is this true ???
A statement CanadianOlds made in a different post caught my eye (post # 9 in this link below):
Compression static, dynamic and runner size post in the Racing and High Performance Section
Whoa - is this true? I spent $3350 with Mark on my heads and now I find out that Champion is who actually did my heads?
Is this the place?
Hmmmm - inquiring minds want to know. Not sure how well this sets with me.
Paul
who does your machine work?
who does your head work?
do you port your own heads?
Or how about you tell us what you actually do…we know Champion does your heads because you let that out of the bag when something went wrong .is that what you call standing behind what you do? So they do all your block machining as well?
Is this the place?
Paul
#94
Is this the place?
Hmmmm - inquiring minds want to know. Not sure how well this sets with me. Paul
Is this the place?
Did you contact Mark to have your Speedmaster heads CNC'd ?
Did you change the combustion chambers twice that required reprogramming twice ?
Did you get what you asked for ?
#95
Is this the place?
Paul
Is this the place?
Paul
All the heads were done by a contracted company that has over $1,500,000 worth of CNC machines and multiple Newan seat machines. I was there throughout the entire process, from flow bench to programming to finished product, repeatedly.
What Ralph said is true, and we discussed it Paul. Your desires changed during the process, necessitating a change in the CNC program, twice.
To my knowledge, ALL the heads that were done along with yours have produced the desired results, ALL of them.
Hope this helps.
#97
