Non Adjustable valve train setup
Old May 21st, 2012, 08:54 AM
XCELERATIONRULES!
Nasty455's Avatar
I've killing some time waiting for a rear end setup to find it's way to my garage.
I'm setting up the valve train on an Olds 350,new cam,lifters,and rocker arms.
Am I supposed to soak the lifters in oil?
Pressurize the oil system with a pre oiler?
The valve train looks extremely loose.
Nasty455 is offline
Old May 21st, 2012, 09:26 AM
Rickman48's Avatar
Pre-pump the lifters - submerge in oil and use a pushrod 'til they feel solid!
Rickman48 is offline
Old May 21st, 2012, 10:03 PM
XCELERATIONRULES!
Nasty455's Avatar
Thanks.
unfortunately I already installed the intake.
I'm going to try adding oil through the push rods and see if I can get some oil in the lifters.
Anyone know the torque settings for the trunnions?
Thanks.
Nasty455 is offline
Old May 22nd, 2012, 04:39 PM
442Harv's Avatar
I have never tryed to fill my lifters with oil before installing them, Olds or Chevy. I do allway prime the oil system, and never had a problem. Some times it takes a long time to prime, especially the BB Chevy.
442Harv is offline
Old May 23rd, 2012, 09:50 AM
XCELERATIONRULES!
Nasty455's Avatar
I bought the shaft to pre oil the engine for my Pontiac engine build.
Will it also fit Chevy and Olds?
I haven't tried to prime the system yet,still working on mounting the ignition system,fuel etc.
I just know the valve train is extremely loose.
The oil keeps the push rods against the rocker arms?
The rocker arms are held down by the trunnions,but seems to be a lot of space in the center opening in the rocker arm.
Nasty455 is offline
Old May 23rd, 2012, 10:30 AM
70Wcars's Avatar
You can prime with a 3/8" six point socket on an extension. Either get a cheap extension and cut it off so it fits in your drill, or use a drill with 1/2" chuck capacity. Tape over the extension to socket connection as insurance you don't drop the socket in the engine. Olds turns the Dist COUNTER CLOCKWISE so turn your priming tool the same...drill running in REVERSE. once oil is pressurized in the lifters you can check the Lifter Pre-load. I am thinking the aftermarket cam and other factors are stacking up to cause the loose valve adjustment you have now. You may need longer pushrods to compensate. Also torque on the Rocker Arm hold downs is 25 Ft/lb.
Hope this helps
Danny
70Wcars is offline
Old May 23rd, 2012, 02:03 PM
XCELERATIONRULES!
Nasty455's Avatar
The cam is just under.500 lift,hopefully won't need custom push rods.
I'm sure it's just the fact that the lifters are dry.
Thanks for the help.
It will be a few days before I get going again.
Sister is getting married Saturday,and need clean hands for the day.
Hurts having all these parts available,and trying to stay out of the garage.
Nasty455 is offline
Old May 23rd, 2012, 03:09 PM
Tony
archeryshooter's Avatar
if you go to comp cams website they have a good u tube video on how to make sure that your pushrods are the right length its not a bad idea to check with the length tool you can get from jegs or summit
archeryshooter is offline
csouth
April 3rd, 2013 10:24 AM
66ninetyeightls
April 23rd, 2010 05:48 AM
Oldwolf
November 17th, 2009 07:48 AM
TWS
January 10th, 2009 02:50 PM
blawton442
November 30th, 2008 05:20 AM
Quick Reply: Non Adjustable valve train setup
