Timing and Spark Plug Gap for 350
Old October 31st, 2007, 10:23 AM
ChrisM's Avatar
Hello all,
I recently converted the 350 engine in my '73 Delta 88 to a Pertronix electronic ignition. I need to set the timing and my repair manual says to see a sticker in the engine compartment, but the owner before me had removed all stickers in a repaint effort. Does anyone know what the proper timing setting is for my car? Also, I want to put a new set of spark plugs in, but I don't know what the gap should be set at?
Thank you all in advance,
Chris
ChrisM is offline
Old October 31st, 2007, 03:06 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
I believe it is 17 or 18 degrees below top dead center @1100
gap for a 307 is.060
I would think they are the same.
I'd go with that on ACDelcos
If you're using Champions id go .040
J-(Chicago) is offline
Old October 31st, 2007, 06:00 PM
Junior Member
88 coupe's Avatar
Use of Pertronix trigger, in place of points, doesn't change the settings.
Plugs = AC R45S gapped at .035"
Timing = 12° BTDC.
Norm
88 coupe is offline
Old October 31st, 2007, 06:15 PM
Wow, slight difference between a 1980 350 and a 1973 350.
Thanks Norm.
Old October 31st, 2007, 06:19 PM
Past Administrator
Oldsguy's Avatar
Oh for sure! In '69 the gap was .030 and the advance was only about 8 btdc. Just shows that the engines will run well with varying settings depending upon the distributor and the junk loaded on top of the manifold for smog regs.
Oldsguy is online now
Old November 1st, 2007, 08:41 AM
ChrisM's Avatar
Thank you all for your help! I will try out the plugs gapped at .035 and the timing at 12 degrees BTDC tonight. This is all very new to me, and I am bumping my way around this car. Thanks again.
Chris
ChrisM is offline
Old November 1st, 2007, 03:37 PM
Originally Posted by Oldsguy
Oh Just shows that the engines will run well with varying settings depending upon the distributor and the junk loaded on top of the manifold for smog regs.
So do you have to compensate if you rip all of that crap out?
Old November 1st, 2007, 04:43 PM
Junior Member
88 coupe's Avatar
No reason to.
That "junk/crap/etc" has nothing to do with the spark advance/plug gap, or the power output of that engine.
Might be an oversimplification, but, advance requirements are determined by cylinder pressures (compression ratios) and the plug gaps, by fuel mixtures.
Norm
88 coupe is offline
Old November 1st, 2007, 09:01 PM
Thanks again Norm.
I appreciate your straight answering style on here.
Old November 2nd, 2007, 10:18 PM
Redog's Avatar
point ign .032
HEI ign .045
When I when from points to HEI, I regapped all the plugs from .030 to .045
Redog is offline
Old November 3rd, 2007, 08:23 AM
Junior Member
88 coupe's Avatar
Originally Posted by Redog
point ign .032 ........ HEI ign .045 .......
Nothing to do with the distributor.
Increase in gap was because of the change to lean mixtures that were used to meet emissions standards.
On a pre '74 factory engine, .032" or .045" will work fine. '74 and later will need .045" to run satisfactorily.
Norm
88 coupe is offline
Old March 6th, 2009, 11:30 AM
ChrisM's Avatar
Timing = 12° BTDC.
Norm
What RPM do I set the timing at? 1100?
ChrisM is offline
Old March 6th, 2009, 11:33 AM
Redog's Avatar
^^ Yes
Redog is offline
Old March 6th, 2009, 06:10 PM
ChrisM's Avatar
^^ Yes
Do I need to plug any vacuum lines? I recently had a MSD coil and distributor put in and I thought I heard somewhere that you have to plug some vacuum lines when setting the timing. If I do, which lines do I plug?
ChrisM is offline
Old March 7th, 2009, 08:07 PM
Junior Member
88 coupe's Avatar
Originally Posted by ChrisM
........ which lines do I plug?
Remove and plug the hose from the vacuum advance canister.
Set the advance.
Unplug and return the hose to the can.
Norm
88 coupe is offline
bonesbmx
June 2nd, 2020 02:10 PM
dallasite21
May 25th, 2012 09:07 PM
yeahbuddy
April 27th, 2012 10:45 AM
ChrisM
November 1st, 2007 02:23 PM
66starfire
January 3rd, 2007 10:31 AM
Quick Reply: Timing and Spark Plug Gap for 350
