Overheating my 65
Old August 17th, 2017, 06:24 PM
My65Oldsf85's Avatar
Overheating my 65
Bought me a 65 Olds F 85 with a 1968 , 350 V8 30 over with a Lunatic mild cam. It runs hot 230,got a new aluminum radiator with a shroud and electric fan 1900 cfm, ,nothing, got worse, heads out resurfaced, all new, nothing, water pump new, nothing, thermostat new, nothing,. Idle climbs up to 230 in about 30 minutes.
Driving it 230 in about 13 minutes.
It is an actual car but it is not hooked.
compression test 120 to 125 every cylinder.
Any ideas?
My65Oldsf85 is offline
Old August 17th, 2017, 06:33 PM
What distributor and carb are you using? What is your timing set to? What temp thermostat temp are you using? Can you post some pictures of how your radiator and fan setup is?
oldcutlass is online now
Old August 18th, 2017, 01:58 AM
'87 Delta 88 Royale
rustyroger's Avatar
Just a thought, is the temperature sender compatible with the gauge?.
Does it puke coolant when you shut it down?.
Are you running ethanol blended gas?.
Let's dig this up and bury it again; Have you tried a stock clutch fan?.
Roger
rustyroger is offline
Old August 18th, 2017, 04:55 AM
Thanks for the input.
The answers to the best of my abilities,
Acceleration Distributor
Edelbrok 4 barrel
180 thermostat
Timing, no clue
New Monster Cooling 3 core aluminum radiator with a shroud and a 16 " 1,900 air moving volume
I know is pulling from radiator towards engine
I think that's it.
thank you for the response
Victor
Old August 18th, 2017, 05:00 AM
Other answers
Ethanol free gas
When I stop or ride, it's spitting water to the reserve bottle
I can hear the water boiling
Victor
Old August 18th, 2017, 08:39 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Test with another known good gauge even if you need to purchase another gauge & sender. This is step one...verify the temp is the actual temp.
You need to know where the timing is. 10-12 BTDC is a good start.
How deep is the fan into the shroud? The blades should be 1/2 way into the shroud. If you still have a mechanical fan attached?
Are the belts tight?
Is the pump a factory Olds pump?
What PSI cap are you using?
Automatic or Stick transmission?
Are you using coolant? Or is it just ebb/flow on the overflow bottle?
Is the coolant mixed 50/50 using distilled water?
So you get the same results regardless if your idling or at highway speeds?
Snap a pic of the pump and belts as well as the radiator.
droldsmorland is offline
Old August 18th, 2017, 09:18 AM
I'm assuming you mean Accel distributor and its an HEI. If you don't know a picture will help. Retarded timing and a lean carb setting can/will cause overheating.
Old August 20th, 2017, 01:54 PM
Problem still
So I wrote about my 65 F 85 overheating.
will the distributor or timing make a car overheat? I have change all cooling parts.
thanks
Victor
Old August 20th, 2017, 02:19 PM
1arunem's Avatar
If timing is off it can cause it to run warm.
1arunem is offline
Old August 20th, 2017, 02:45 PM
tangokilo's Avatar
Vacuum advance not working can cause running hot. Tom
tangokilo is offline
Old August 20th, 2017, 04:47 PM
I merged your 2 threads and moved it to the engine forum. I already mentioned that timing and lean fuel conditions can cause overheating and asked distributor is installed and setting your running. We cannot help you until you post a pic of your distributor and tell us what your timing is. Also need some pictures of your radiator, fan, shroud setup.
Old August 20th, 2017, 05:36 PM
AZ520's Avatar
4 row radiator and a mechanical fan, high flow 180 t-stat helps as well, here in the desert I played that game, even with 2 3,000 cfm fans and and a 4 row would not do it. Another tip is be sure to run dist. to manifold vacuum and not ported. At idle you want 45 degrees advance to help cool it.
AZ520 is offline
Old August 22nd, 2017, 01:17 AM
shiftbyear's Avatar
A smaller water pump pulley will spin faster at idle. 50/50 mix seems a little thin, I prefer concentrate and some 50/50. good luck
shiftbyear is offline
Old August 22nd, 2017, 03:34 AM
Proud Viet Nam Veteran
redoldsman's Avatar
Actually water cools better than coolant so a mixture with less coolant will actually cool better.
redoldsman is offline
Old August 22nd, 2017, 06:39 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Those electric fans may not be worth a crap. Even still, running down the road, they shouldn't be needed to stay cool, only in traffic. I would pull the thermostat and go from there.
olds 307 and 403 is offline
Old July 7th, 2021, 11:31 AM
409sleepr's Avatar
I have a 65 Cutlass F 85 as well it has a Olds 403 w 350 heads 65cc chambers. it runs hot just like what your saying . much the same type of repairs and mods . my compression is higher 160 167 ps i im going to pull some timing out of it and change the set up on the carb - carter 750 rods and jets run it a little richer , plugs look whiter than I like needs to be more of a tan color . that's my 2 cents
409sleepr is offline
Old July 7th, 2021, 11:45 AM
Are you really going to dredge up every single thread that talked about cooling in a 1965? This is dangerously close to SPAM. You've already got what, three or four different threads going? We get it, you've got a problem. FYI, you'll get the best answer soonest if you confine all responses to a single thread so that everyone sees every other response. This way incorrect info can be identified and corrected as quickly as possible
joe_padavano is offline
Old March 1st, 2024, 07:46 PM
Cutlass Fan's Avatar
Is it boiling over when idling? If not I wouldn't worry too much, 220 degrees won't hurt it. Have you checked to ma sure your thermostat is opening fully. Like I said a fresh rebuild will run hot, especially at idle, until it is broken in.
Cutlass Fan is offline
Old March 2nd, 2024, 02:42 AM
Dynoking's Avatar
Your'er responding to 3+ YO thread.
Dynoking is online now
Old March 2nd, 2024, 09:39 AM
Oops, lol
Old March 2nd, 2024, 11:14 AM
Actually it's almost a SEVEN year old thread that was last dredged up three years ago.
Old March 2nd, 2024, 02:13 PM
72Cutlass S
gs72's Avatar
I wonder if he ever got it cooled down?
gs72 is offline
Old March 4th, 2024, 01:00 PM
Onit's Avatar
Nope.. seen him yesterday at Circle K with water hose and pack of smokes. Great advice everybody..😁
Onit is offline
Old March 4th, 2024, 03:14 PM
72Cutlass S
gs72's Avatar
Maybe it's that Lunatic cam he says he is running. 😂 If you see him again tell him to ditch the electric fans and go back to a stock fan with a heavy duty fan clutch. Thats what fixed my car.
gs72 is offline
labrats804
July 19th, 2007 07:16 AM
skibone
January 13th, 2007 07:29 PM
<cathy>
November 22nd, 2004 02:07 PM
martine
January 3rd, 2004 11:29 AM
martine
August 16th, 2003 07:49 AM
Quick Reply: Overheating my 65
