1966 330ci High Compression?
Old September 8th, 2010, 06:58 PM
TripDeuces's Avatar
Is there an easy way to tell if you have the high or low compression 330ci? It came with a Quadrajet and a Jetaway 2pd.
Thanks,
George
TripDeuces is offline
Old September 9th, 2010, 07:53 AM
this is not my car lol
scubastever's Avatar
i believe the 330 in 66 was high compression (10:25 : 1 ) on the 4 barrel intake applications...
2 barrel had a lower compression ratio (9:1)
V8 - 330 2-BBL250 @ 4800335 @ 2800 (bore x stroke) 49.63.938 x 3.385 CR 9:135
V8 - 330 4-BBL320 @ 5200360 @ 3600 (bore x stroke) 49.63.938 x 3.385 CR 10.25:135
scubastever is offline
Old September 9th, 2010, 07:58 AM
stan 65 cutlass's Avatar
im sure the heads were the same size, but the pistons are the difference,cam may be different as well i think
stan 65 cutlass is offline
Old September 9th, 2010, 08:00 AM
im sure the heads were the same size, but the pistons are the difference,cam may be different as well i think, by the way your avatar is creepy.
Old September 9th, 2010, 09:13 AM
TripDeuces's Avatar
Lol, I'm sure the old school guys can tell you what that avatar is from. This will be a good trivia question. Circa 1971
Thanks for the info all.
Old September 9th, 2010, 09:50 AM
tonycpe's Avatar
easy way to tell?
try to run it with low octane gas .
My '67 330 high compression cutlass only likes 93 octane.
tonycpe is offline
Old September 9th, 2010, 10:04 AM
o ive seen clockwork orange many years ago, twisted stanley kubrick. its still creepy looking lol
Old September 12th, 2010, 09:10 AM
Warhead's Avatar
Would you rather he replaced it with a Barney avatar?
THAT WOULD BE CREEPY HERE!!!
Jim
Warhead is offline
Old September 12th, 2010, 10:25 AM
better yet run his avatar on barneys web site
Old September 12th, 2010, 02:12 PM
I've felt the same way ever since I saw that avatar. It was creepy then and it still is.
joe_padavano is offline
Old September 12th, 2010, 04:13 PM
TripDeuces's Avatar
Wow, tough crowd
Old September 13th, 2010, 04:51 PM
67 Cutlass's Avatar
Yea, I went to high school with a guy that looked just like your avatar. YES... he was creepy! I do remember Clockwork Orange... strange stuff for sure!
Sooo... back to the OP. There should be a W stamped on the head after the numbers. I think that's suppose to indicate a high compression 330?
67 Cutlass is offline
Old September 13th, 2010, 05:40 PM
TripDeuces's Avatar
I know it doesn't like low octane fuel so I'll look for that 'W' tomorrow.
Old September 13th, 2010, 06:12 PM
Oldsmaniac's Avatar
HC would have an orange/red air cleaner and gas cap would say premium fuel only if the original ones are still there with car.
Oldsmaniac is offline
Old September 13th, 2010, 06:15 PM
TripDeuces's Avatar
Good to know, thanks. My AC is red/orange and I think gas cap is original. I'll check tomorrow. Out of curiosity what color AC is the low compression one?
Old September 13th, 2010, 06:40 PM
Oldsmaniac's Avatar
Low Compression would have come with a black air cleaner.
Old September 13th, 2010, 06:44 PM
linear59look's Avatar
The low compression ones were black, and if im not mistaken they use a different, smaller housing that has a longer, thinner and more rounded snorkel.
linear59look is offline
Old September 14th, 2010, 02:19 AM
67 Cutlass's Avatar
To correct myself... there should be a G at the end of the stamped pad on the passenger side head.
Old September 14th, 2010, 09:37 AM
TripDeuces's Avatar
Just checked the heads and they do indeed have a 'G' stamped on them. The gas cap also says 'Important Use Premium Fuel Only' I appreciate all the good information everyone. I'm happy I have the high compression engine but it just seems sluggish to me. I guess I'll have to fix that with the big block and the Tri-Carb setup
Thanks,
George
Old September 14th, 2010, 10:20 AM
citcapp's Avatar
Thanks,
George
Now your talking!!!!!!!!!!!
citcapp is offline
Old September 14th, 2010, 10:34 AM
theres also the forced induction option ...
Old February 5th, 2014, 08:03 AM
Racing Palm Tree's Avatar
Thanks,
George
So what does the W indicate? I have "W" and am curious if I have a High Compression engine
Racing Palm Tree is offline
Old February 5th, 2014, 08:37 AM
Trying to remember member
wmachine's Avatar
Page 05 of the Chassis Service Manual tells you what the engine unit numbers mean. Available free of charge at Wild About Cars:
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and the Automotive History Preservation Society library growing daily.
Free to join, free to learn.
wmachine is offline
Old February 5th, 2014, 10:30 AM
Check and make sure the transmission switch pitch function is working correctly. If it's not it can be a real dog. Engine timing is also very important. Also ensure your throttle linkage is opening the carb all the way at WOT.
oldcutlass is offline
Old February 5th, 2014, 04:41 PM
jag1886's Avatar
Wow, tough crowd
I saw that movie when it first came out, it was weird and creepy then but compared to todays crap it's pretty mild, I have it in my DVD collection.
I always think of Clockwork when I hear Ludwig Van.
jag1886 is offline
Old November 14th, 2017, 04:21 PM
67cutlassguy's Avatar
High
high compression heads for 66-67 will have a stamp starting with W, then production#, then end in G.
67cutlassguy is offline
Old November 14th, 2017, 04:23 PM
...no offense, that avatar/picture is kinda dumb! Lol get a nice picture of an olds, or a nice set of *****/butts
Old November 14th, 2017, 05:29 PM
Old November 14th, 2017, 05:32 PM
[QUOTE=67cutlassguy;1055972]...no offense, that avatar/picture is kinda creepy Lol get a nice picture of an olds, or a nice set of *****/butts
Old November 26th, 2017, 10:56 AM
brianbeez67's Avatar
If your still following this thread, the "W" on the head stamp should mean its a 330 engine followed by numbers then a "G" or "L" (low compression) hope this helps you out.
brianbeez67 is offline
Old November 26th, 2017, 05:12 PM
  #31
TripDeuces's Avatar
Yup, still following. The engine is sitting in my garage as I restore the car. It's for sale too.
Mr. King
November 16th, 2017 10:02 AM
DouglasOliver
June 7th, 2015 10:28 AM
Tedisthebestkingintheworl
May 29th, 2014 01:43 PM
greenslade
March 29th, 2011 03:56 PM
cts-v
January 10th, 2009 04:55 PM
Quick Reply: 1966 330ci High Compression?
