jetaway tranny throttle control switch
Old December 30th, 2023, 02:01 PM
1964vistacruiserwagon
mathon's Avatar
Reinstalling throttle control switch on 1964 Vista with Jetaway. Where does the yellow wire plastic connector attach to? Also on the back side of the switch it looks like there are some cut off wires, are they needed? I do have the yellow/black wires going to the tranny hooked up. Is this switch really needed if I dont drive the car over 45 mph? What if I left this part off the car all together?
mathon is offline
Old December 31st, 2023, 03:28 AM
The 1964 cars have TWO switches. The one in your photos is the switch for kickdown that operates both the kickdown solenoid and the switch pitch converter solenoid at wide open throttle. There is a second switch that is part of the dashpot assembly that also operates the converter solenoid at idle to give you high torque multiplication off the line. I don't see that one in your photos.
The single yellow wire in this photo connects to the power feed. The black and white wires with the rubber boot plug into the trans. The two spade terminals on the underside of the switch are where the wiring from the dashpot switch connects.
The dashpot switch looks like this.
joe_padavano is offline
Old December 31st, 2023, 09:55 AM
mathon's Avatar
Thanks for the information. My car drives just fine around town without the dashpot. is there any harm driving without it? I will try and source one when time allows...
mathon is offline
Old January 1st, 2024, 01:37 AM
Not using the switch pitch feature at low speeds will reduce off-the-line acceleration and marginally increase wear on first gear clutches due to potential additional slippage, but frankly it's not something I'd be too concerned about.
69Chrgr
July 28th, 2022 12:40 AM
carlos442
July 1st, 2021 12:50 PM
jerbear2
April 16th, 2021 05:10 AM
MBOlds98
February 10th, 2021 06:37 PM
TripDeuces
September 18th, 2010 08:29 AM
Quick Reply: jetaway tranny throttle control switch
