Transmission Oil Change - Newbie
Howdy! Just wondering if anyone can give me some tips on dropping the trans pan and changing the fluid/filter. I've never done it before but it seems fairly easy and thought I'd save myself 50 bucks or so and do it myself.
I'm changing the oil on my '86 Custom Cruiser first...307 with 200-4R.
It shifts great and no problems that I'm aware of. The pan gasket looks damp so I think it's crapping out...that's why I want to change it...before it starts leaking all over.
Do the filters just pop off on these or do they have bolts?
Thank you!
Thank you!
The filter usually just has 2 bolts or screws on it. You'll see it once the pan is off. Remember what holes the filter bolts go in.
Take all the bolts out of the pan, and drop the pan down.
Clean up your pan, lay the new gasket on the pan lip, put a few bolts in the corners to hold the gasket to the pan, and hand tighten it up.
Torque pan bolts to 13 lb ft.
Thank you!
Thank you!
In a big car like a 98? It was no screamer off the line; in fact I think it was underpowered, but the 200-4R did give it an economical final drive ratio.
Anyway, let us know how it turns out.
Yeah it's a bit of a slug...though since I've tuned up the engine and fixed some stuff it moves a long pretty good. My Toronado is noticeably stronger, though it also has about half the mileage on it and is probably close to 500 pounds lighter...lol.
The wagon has about 115K...but like I said, it shifts great. I haven't noticed any slippage or anything with it.
Yes exactly...it moves great up until that point...but you know last night I got up to 60 without even noticing...seriously...I had no idea I was going that fast...lol.
I will change the differential fluid as well...it most likely should be changed. How do I know if I have the limited slip?
The Toro has the THM-325-4L. I have to change the fluid on that too...but really it's in super good shape so I've been concentrating on getting the wagon up and running...it was in dire need of a tune up, etc.
Well I changed the fluid and filter on my Toronado today. Damn what a messy job, ack! The filter looked fairly clean and the fluid wasn't that dirty, so I'm not sure as it really needed it, but it was shifting kind of hard so I decided to flush it. I also added a bottle of Lucas Transmission treatment...seems like good stuff.
Now I have to do it in the Custom Cruiser...that pan is leaking...but I figured I'd just wait until I change the oil next time.
haha. I had a fairly good sized puddle under the car. Of course where I had the drain pan positioned, the trans pan fell on the other side, so it made quite a mess
It would have been easier had I raised the car more. I have this major phobia with working under the car so I never raise it up high..lol. I'm always afraid the jack stand will fail and crush me....valid worry i guess, but I shouldn't so much
