troubles w/my 1964 hydramatic
Old February 25th, 2009, 06:35 PM
tury801's Avatar
Question troubles w/my 1964 hydramatic
Hi guys, I need some tips to find out what's wrong w/tranni, this tranni Up-shifts really good from 1-2 to 3rd and it feels really strong but when I got to a stop or start to slowdown it takes too long to down shift by it self the car starts to pull till engine struggles then it does go from 3rd to 2nd, I'd replace oil and cheked the filter looks good, any suggestions? is there any vacum hose that Im not aware? Thanx.
tury801 is offline
Old February 26th, 2009, 05:34 AM
d2_willys's Avatar
If after what Coldwar suggested does not improve the downshift then 1) you may have sticky governor weights, 2) sticky downshift valves in valve body. It sounds like it might be a simple fix without yanking the box, (other than governor weights, which I can't recollect if they are easy to get to while in car).
d2_willys is online now
Old February 26th, 2009, 05:55 PM
tury801's Avatar
Thumbs up thanks so far guys.
Thanx cold war and d2 ******, so far for the tips I will try to adjust the throttle valve control link and go from there, Im not shure if I have the manual but I guess I can go to the library thanks again.
tury801 is offline
Old February 27th, 2009, 01:52 AM
Junior Member
88 coupe's Avatar
........ it takes too long to down shift by it self the car starts to pull till engine struggles then it does go from 3rd to 2nd ........
Make sure the engine is tuned to factory specs. Particularly the warm idle speed. Should be 500-550 RPM.
Norm
88 coupe is offline
MN71W30
July 11th, 2009 06:09 AM
The Stickman
May 24th, 2009 06:09 AM
jensenracing77
Site Help
May 20th, 2009 05:31 AM
Kaline
October 21st, 2008 10:12 PM
pompman
October 22nd, 2006 08:20 PM
Quick Reply: troubles w/my 1964 hydramatic
