Won't kickdown
Old May 11th, 2010, 03:44 PM
jaymann's Avatar
Won't kickdown
I've adjusted all the linkage as per the manual and the car seems to be shifting well now. But it just won't kick down!
I think I may be missing a spring on the linkage at the carb. Anyone have a picture of a stock setup. I definitely have a hole on top of the throttle linkage that looks like it would hold a spring....possibly for the kickdown?
jaymann is offline
Old May 11th, 2010, 06:09 PM
svnt442's Avatar
What trans?
svnt442 is offline
Old May 11th, 2010, 09:11 PM
jaymann's Avatar
sorry , I was posting that at work and someone stopped in and interrupted me!
It's a 1956 Jetaway...Also known as the dual coupling hydramatic.
jaymann is offline
Old May 12th, 2010, 06:49 AM
Fletch's Avatar
I have a stock 57 Jet away linkage(in use) are they the same as a 56 ???
Fletch is offline
Old May 12th, 2010, 06:55 AM
Those manual throttle valves are hard to set correctly. Hopefully someone can post some pics which will help you out. Good luck.
Olds64 is offline
Old May 17th, 2010, 02:49 PM
jaymann's Avatar
Hi Fletch.
I wouldn't know if a 57 is the same or not. Do you happen to have a pic of your carb linkage?
jaymann is offline
Old May 17th, 2010, 06:41 PM
Fletch's Avatar
yes I can email/post picture sometime this week,
Fletch
Fletch is offline
Old May 19th, 2010, 09:31 PM
jaymann's Avatar
here's a picture of my linkage. I drew an arrow to wher I think I'm missing a spring
jaymann is offline
Old May 20th, 2010, 06:15 AM
Fletch's Avatar
Thanks.. I will look tonight and email you as to the linkage I have on the 57.. cloudy here, thus bad lighting for my phone camera..
Regards,
Fletch
Fletch is offline
Old May 20th, 2010, 10:44 AM
Junior Member
88 coupe's Avatar
Check page 3-84 in your manual, the image at the bottom right.
Norm
88 coupe is offline
Old May 20th, 2010, 12:49 PM
jaymann's Avatar
That picture doesn't show where it hooks to on the bottom. I do believe that spring is part of the problem considering it's on the downshift lever!
jaymann is offline
Old May 20th, 2010, 05:18 PM
Fletch's Avatar
The hole you referance is un used... The only spring is the one connected to the firewall assmbly. About 2 inches long and 1 1/2 in diameter.
I believe the book will referance the screw/bolt nut which pushes down on the assembly. Adjustment at the trans and pedal are critical. I made a cardboard measure tool to get the proper spacing for the pressure lever. The book (3-81, 57 shop manual) has to be follwed closely.
It has taken several weeks to get it right .
Fletch
Fletch is offline
Old May 21st, 2010, 09:43 PM
Junior Member
88 coupe's Avatar
Originally Posted by jaymann
That picture doesn't show where it hooks to on the bottom ........
It's been a while, but it seems like it was self explanatory. With the carb closed, it should go straight down less that 2". Do you have the correct spring?
........ I do believe that spring is part of the problem ........
It is.
Originally Posted by Fletch
The hole you reference is un used ........
Pages 3-79 (top) and 3-89 (bottom right) in your '57 manual.
........ The book (3-81, 57 shop manual) has to be followed closely ........
There are some small differences between your '57 and his '56 manuals.
........ It has taken several weeks to get it right.
Shouldn't take more than a few minutes.
Norm
88 coupe is offline
Old May 22nd, 2010, 09:47 AM
jaymann's Avatar
Norm
The biggest problem with setting this up is 54 years of people messing with it. If this car was as it left the factory, It would probably take a few minutes.
I don't have the spring. If I did, I probably would have figured out were it goes.
The linkage is a mess too. Something's not right because when I followed the steps in the manual, I got to the step about adjusting the shift linkage and could not adjust it to within spec. I had the rods shortened as far as they would go and still couldn't get it into spec.
I'm not sure if they're bent or have been swapped for the wrong pieces somewhere along the way.
jaymann is offline
Old May 27th, 2010, 02:32 PM
Fletch's Avatar
Jaymann: Owe you more info.... The spring(which prevented proper upshift into 3rd) was also missing from the bell crank, and had not been on the 98 for some time. Spring clip attaches to the hole on bell crank and keeps an upward pull on the trans pressure rod so to be insink with carb linkage..
Summary... 2 springs, one on firewall and one on the bell crank.
Fletch.
Fletch is offline
stevengerard
September 10th, 2014 03:17 PM
bigbrother
17
March 11th, 2012 06:45 PM
nevadacutlass
October 8th, 2007 07:28 PM
nevadacutlass
October 7th, 2007 01:14 PM
bigbrother
June 18th, 2007 12:34 PM
Quick Reply: Won't kickdown
