Click Here
Extended wheel studs.
Old April 16th, 2011, 05:58 PM
cuttyroe's Avatar
I just got some craiger rims and my studs are not long enough. It is just about an inch shy, if that much. Is there a certain length I should ask for and is there a maximum length? Going on my 72 cutty.
cuttyroe is offline
Old April 16th, 2011, 07:03 PM
stan 65 cutlass's Avatar
with the right lug nuts they should be ok
stan 65 cutlass is offline
Old April 16th, 2011, 07:15 PM
cuttyroe's Avatar
But the studs dont come out past the rim. Is it wrong rim size or studs need upgrading
cuttyroe is offline
Old April 16th, 2011, 07:43 PM
OLDSRALLYE350's Avatar
Sounds like you have the cragar/weld superlite II wheels or something thats the same for the added the strength the longer wheel studs are required examples can be found here http://www.jegs.com/i/JEGS-Performan...ductId=1224592 they can also be found at your local speed shop. They are required if you plan on running the car at the dragstrip if only for fun, They are supposed to check the car and it is a safety issue. When i went to the superlite II wheels i had to put in these because the spacer in the middle of the wheel made the studs about a inch to short .
OLDSRALLYE350 is offline
Old April 17th, 2011, 07:43 AM
car guy
gearheads78's Avatar
unless you are racing you don't need longer studs. You just need the correct long shank lug nuts. I think they are 1 7/8" shank if you remember right. Verifie that though. They are known as SST lugs
gearheads78 is offline
Old April 17th, 2011, 09:16 AM
cuttyroe's Avatar
Thanks. Id like to do the studs anyway. But question on the shank lug nuts. These lug nuts fit through the rims to reach the studs?
cuttyroe is offline
Old April 17th, 2011, 10:44 AM
InfoJunkie
InfoJunkie's Avatar
With the proper lug nuts they fit into the rim as in the pic attached.
If you do the studs you will need open end lug nuts as longer studs will protrude past the end of the lug nut as in the second pic.
The proper wheel nuts are all you need. With a pic of the wheels the guess work is out of trying to figure out the shank length.
InfoJunkie is offline
Old April 17th, 2011, 12:06 PM
cuttyroe's Avatar
Thanks for the info. Is that why they call you that?
cuttyroe is offline
70442rag
February 12th, 2014 05:49 AM
Delmont 88 PA
September 26th, 2013 06:10 PM
naphtali5725
June 27th, 2012 08:27 PM
Tedd Thompson
March 26th, 2012 07:51 PM
The Stickman
March 16th, 2010 07:34 PM
Quick Reply: Extended wheel studs.
