DIFFERENTIAL SWAP
DIFFERENTIAL SWAP
I have a 71 cutlass s, 350, auto, non-posi 2.56 gears.I want to put a diff from a 70 chevelle. This is a posi with 3.08 gears. what kind of trouble will I have when I try to put it in.
Yeah they are both 10 bolts.I had to make new spring seats and weld them on because on the cutlass they sit farther ahead than on the chev.the lower control arm hangers look like they are farther apart on the chev I think I should move them closer before I try to install so the control arms will fit without a problem.
I'm pretty sure that the rear end in the car is original.The one that I want to put in, I got from under a circle track car.I was told it was out of a chevelle.I'm having a hard time reading the ID numbers on the axle housing.The rear end looks the same other than some slight differences in measurements
henryk8398
Drivetrain/Differentials
February 26th, 2010 02:43 PM
